6131 Rm-115 Strange problem Someone can explain what this mean: Updating SIMLOCK...OK missing NPC data in the RPL file, skipped. Certificate programmed successfully ! Phone Type: RM-115 (Nokia 6131) SW Version: V 03.70 12-05-06 RM-115 (c) Nokia. Imei plain: 35629801494748-5 Product Code: 0537699 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 356298014947485 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Bad Flash IC / Bad CPU ? Flash IC changed twice ... same situation - everything can be rewrited, but SIM-lock is not OK ... |
save full backup rpl . repar recover cert.next repair sd go to pm super sd auther load pm full next wright pm next phone unlock phone work ok |
if your mobileex.log activated try rename first to other. when get error do update SIMLOCK data,please post your mobileex.log br, |
@debeliamark I am interested to solve your problem by team viewer only, there is a reason. Thats i hope and sure your phone should be ok. Br. Shashank |
