Old 02-10-2010, 09:40   #1 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 352
6210 Navigator (RM-408) No certificate found in the database !
ERROR: No certificate found in the database !
Scan Phone:
Phone Type: RM-408 (Nokia 6210 Navigator)
SW Version: V 08w35.13 10-02-09 RM-408 (c) Nokia
Imei plain: 35683102141651-4
Product Code: 0570079
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Recover CERT:
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0A80010ABE4A8B52FF14F3F63878069F8E56A314
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 1.37.1 revision: 0.0 size: 0x3B80
 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040  - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAPIDOv11_algo.fg [XSR 1.5]  version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 4AA07663215C623237BF8A43EC71D55819B7DC6E
Reading RAP NPC  (0x168 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
Old 02-10-2010, 10:35   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
must repair this first
SIMLOCK invalid!
try with standart metods
REPAIR SIMLOCK - Determind first what SL level you got
> Choose Repair SIMLOCK
> Tick make SIMLOCK RPL
> Click Repair SPLock
if have error on repair simlock
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
You got Only NPC? NO PROBLEMO!
if do "Recover CERT" , if doesn't work
check this
Just in case if Recovery via Server doesn't work.......
need more file about CCC,HWC and VARIANT
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
ERROR: No certificate found in the database WAJID PNR MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 03-13-2010 20:57
ERROR: No certificate found in the database ! sumon.bd MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 03-01-2010 22:12
ERROR: No certificate found in the database ! neo_2005 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 18 01-28-2010 15:18
no certificate found in database rajufzr MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-26-2010 11:27
Invalid account. ERROR: No certificate found in the database ![old post] vistasamir MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-21-2010 20:36
Page generated in 0.27968 seconds with 8 queries
