12-31-2012, 20:03 | #1 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 110856 Status: Offline Thanks Meter: 5 | 6230b Performing Flash Authentication ...flashing terminated ! Using device: HTI, FW ver: 00.50, SN: 0100A44D Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0039 [Samsung KEE00E00CM Eija NAND,64 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Processing MCU file: rh12_28_11005.500 [TIKU BT2,TIKU ALGORITHM] size: 8.67 MB Supported Ids: 1052 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0039 [Samsung KEE00E00CM Eija NAND,64 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...flashing terminated ! how do i bypass this? im even try with rh-12 firmware and still the same! thanks for any help |
