Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 637351 Status: Offline Thanks: 100
| 6230i flash help tryed to flash nokia 6230i, bat with errors, here is log Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 004C19B5:3B8ADA60 ASIC type: 6 UEM Imei: 35761600587840 Flash Imei: 35761600587840 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35761600587840_BACK.rpl" Processing file: rm72_73_11003.800 as MCU [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 004C19B5:E986DA60 Area [00000000-0000FFFF] erased in 0.437 s Area [00010000-009FFFFF] erased in 1 min 6.922 s Area [00A00000-00B3FFFF] erased in 8.500 s Area [00B60000-00FAFFFF] erased in 27.047 s Flash programming ... Programming completed in 1 min 52.562 s File Processed in 3 min 56.328 s Processing file: rm72_73_110E_03.80.ucp_e as CNT [TIKU BT2,TIKU EIJA SSR] size: 3.98 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...flashing terminated ! Flashing terminated with error(s) in 4 min 52.641 s RX Buffer: 0400000000B172 |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: P@Ki$t@n Age: 30
Member: 777415 Status: Offline Sonork: 1589702 Thanks: 284
| Quote:
| | #6 (permalink) |
| i flashed succesfully, first flashed only ppm, after that i flashed only cnt....that's all, i tryed with hwk, but no succes, with mx-key just like work |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6230i flash help | sebY7676 | HWK | 1 | 01-30-2010 14:02 |
| whats happening with 6230i flashing,HELP | nesteam | MT-BOX | 2 | 02-08-2006 20:51 |
| 6230i flash help! | Saff | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 01-11-2006 12:57 |
