01-27-2010, 16:28 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 326941 Status: Offline Thanks Meter: 16 | 6230i Flash Problem Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Processing file: rm72_73_11003.800 as MCU [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...flashing terminated ! Flashing terminated with error(s) in 1 min 13.219 s RX Buffer: |
01-27-2010, 18:12 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | @syed tugeer:have you use the lates module? DCT4: Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 Processing file: rh19__06.310 as MCU [DCT4,DCT4 ALGORITHM] size: 5.26 MB Supported Ids: 0120, 1120, 2140, 2141, 2142 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4AF89:1DA6DA60 Area [01000000-0100FFFF] erased in 0.547 s Area [01010000-0154FFFF] erased in 44.906 s Area [01680000-017EFFFF] erased in 12.656 s Area [01EB0000-01FEFFFF] erased in 0.344 s Flash programming ... Programming completed in 36.859 s File Processed in 1 min 44.688 s Processing file: rh19__06.31.ucp_mxv1 as CNT [DCT4,DCT4 ALGORITHM] size: 454.11 KB Supported Ids: 0120, 1120, 2140, 2141, 2142 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4AF89:C3BEDA60 Area [01550000-0167FFFF] erased in 9.813 s Flash programming ... Programming completed in 3.156 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 8.328 s File Processed in 39.062 s Processing file: rh19__06.31v as PPM [DCT4,DCT4 ALGORITHM] size: 1.16 MB Supported Ids: 0120, 1120, 2140, 2141, 2142 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C4AF89:C3BEDA60 Area [01550000-0167FFFF] erased in 9.859 s Flash programming ... Programming completed in 8.172 s File Processed in 25.563 s Flashing completed in 2 min 49.328 s After Flash Processing ... Updating Product Code OK. Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Uploading Product Profile Failed! Updating SIMLOCK ...OK Phone Type: RH-19 (Nokia 3120) SW Version: V 06.31 25-11-05 RH-19 (c) Nokia. Imei plain: 35569700303860-5 Imei OTP: 35569700303860 Product Code: 0516550 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: V Language Pack: English,Chinese S,Chinese T,Bahasa Ind Imei net: 35569700303860 Version: SIMLOCKLIB VERSION 2.28- More TDS-6 boxes supported Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 2.735 s mobileEx main window > Option > Module current: Code: » Nokia Service Tool Version from module: 1.0.0.11893 Version from server: 1.0.0.11893 Module version is up to date. chcek your flash loader directory. |
01-27-2010, 19:14 | #4 (permalink) | |
Member: 326941 Status: Offline Thanks Meter: 16 | Quote:
6230i flash problem , NAND PROBLEM HELP!!!!!!!!!! | maniek27 | UFS2 + UFS3-Tornadoflasher | 13 | 09-12-2006 19:31 |
6230i flashing problem | UnlockBR | Phoenix Black Box | 20 | 06-02-2005 22:21 |
6230i flashing problem | phpl | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-29-2005 08:26 |
