01-05-2010, 15:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | 6300 contact service here is log Phone Type: RM-217 SW version: V 05.50 14-08-07 RM-217 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y !failed ! 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N !no signal 20 BACKUP_BATT N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) here is bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11472, Date: 27-11-2009 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2A3002105DFA6A56E35D6332FF259AE7A1C5EAD9 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: 35643701817404 Original Product code: 0546210 Bluetooth ID: 001C355FA20C Phone Type: RM-217 (Nokia 6300) SW Version: V 05.50 14-08-07 RM-217 (c) Nokia. Imei plain: 3564xxxxxxxxxxxxx Product Code: 0546632 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356xxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 63 Provider: Vodafone, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23415F |
The Following User Says Thank You to X-TRA For This Useful Post: |
01-05-2010, 18:09 | #7 (permalink) | |
Registered User Join Date: Nov 2009 Location: RSA
Member: 1166923 Status: Offline Thanks Meter: 77 | Quote:
SLEEP_X is from 3 components. RETU, THAVO & RAPGSM. But normaly change RETU or THAVO will solve your problem. with best regards | |
The Following User Says Thank You to AOA For This Useful Post: |
01-06-2010, 02:51 | #8 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed means ur software side is ok but 15 SLEEP_X_LOOP Y !failed ! seem to be some thing wrong with hardware open ur handset. just connect s ervive battery thorugh crocodile clips to set , then measure core voltages in system area VIO and VCORE. then u can confirm which IC RITU/TAHVO gone bad there a post in the sticked thread related to N70 contact retailer. see here http://forum.gsmhosting.com/vbb/show...0&postcount=40 this may help u more. regards, NEIL |
01-06-2010, 09:16 | #9 (permalink) | |
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
nokia 5220 contact service 6300 contact service urgent please me | prakash40 | Nokia Hardware & Hardware Repair | 5 | 02-25-2010 09:56 |
6300 contact service after flash | tririval | MT-BOX | 3 | 08-16-2007 16:15 |
6300 contact service | ozeracar | MT-BOX | 1 | 07-31-2007 19:20 |
