Old 02-09-2010, 14:33   #1 (permalink)
Fre3 Crack3r's Avatar
Member: 8784
Sonork: 100.63512
Thanks Meter: 31
6300 contact service !!
Hello
Nokia 6300 contact service flashed and writed a good PM with skip SX4 auth .. and still same pb.
Any good idea to solve it ?
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35980901XXXXXX-6
Product Code: 0546632
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 35980901XXXXXX6
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Regards . .
Old 02-09-2010, 14:35   #2 (permalink)
hamada-almasry's Avatar
Member: 619738
Sonork: 100.1582811
Thanks Meter: 5,176
try this
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
Old 02-09-2010, 14:51   #3 (permalink)
Duytuanmobile's Avatar
Member: 886430
Thanks Meter: 109
the is Mx-key solved Repair SD ok then you free I resolve a tree as your contacsever 6300 SECURITY_TEST failed!
Old 02-09-2010, 15:03   #4 (permalink)
Member: 8784
Sonork: 100.63512
Thanks Meter: 31
Originally Posted by hamada-almasry View Post
Already tired but in step :
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
I get this error :
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.141.167.202
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Can U explain more how U did it ?
Old 02-09-2010, 15:05   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,269
100% Solution Dear Follows carefully
Old 02-09-2010, 18:28   #6 (permalink)
Member: 8784
Sonork: 100.63512
Thanks Meter: 31
All step has been followed carefully but phone still in same situation !
Regards . .
Old 02-09-2010, 19:07   #7 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
nooo if u have followed carefully ur problm got sloved. but u did not followed ...
if ur confused to slove.. u can take my help.. [email protected]
Old 02-09-2010, 19:16   #8 (permalink)
vinay_ab123456's Avatar
Member: 535313
Sonork: 1587826:00
Thanks Meter: 60
1.write pm witout sx4
2.make sd repair
3.make sim lock repair
4.write pm only 1 and 309 field with super sx4
5.write full pm with sx4
try, post ur result
Old 02-09-2010, 19:21   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,224
first write full pm without sx4
second repair simlock
third repair super dondle
fourth super sd auth and write pm (write only field 1 and field 309)
do restore factory
try and post result
Old 02-09-2010, 19:22   #10 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
evn i hd same problm with 7210.. i have sloved it.. u can see here....7210 plz help me...[SOLVED]
Old 02-09-2010, 20:58   #11 (permalink)
Member: 8784
Sonork: 100.63512
Thanks Meter: 31
Hi All
solved ...
Problem was that all PM file i have have bad : 01 , 309 area ..
So i read them from working phone and fixed mine :-)
regards . .
nokia 5220 contact service 6300 contact service urgent please me prakash40 Nokia Hardware & Hardware Repair 5 02-25-2010 09:56
6300 contact service after flash tririval MT-BOX 3 08-16-2007 17:15
6300 contact service ozeracar MT-BOX 1 07-31-2007 20:20
Page generated in 0.31799 seconds with 8 queries
