Old 02-08-2010, 12:06   #1 (permalink)
Member: 63365
Thanks Meter: 3
2630 imei change
How change imei in 2630 - mxkey ??
Old 02-08-2010, 12:25   #2 (permalink)
Member: 63365
Thanks Meter: 3
Please solution step by step
Old 02-10-2010, 15:44   #3 (permalink)
Member: 572236
Thanks Meter: 10
2630 imei change
Hi there
I done a RM298 2630 version 57.20 today for the first time and was easy. Flashed and unlocked the phone first then go to the service tab / IMEI & security / imei changes. Hit scan then replace the imei with the one you want and then hit change imei (i also checked skip unlock) easy.
PhoneType:RM-298
SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia
MCU file: rm298__57.20.mcusw
Trying to find patch position ...OK
New Imei: 356097008111326
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 00563760:3B8ADA60
Area [01000000-0101FFFF] erased in 0.375 s
Area [016C0000-016DFFFF] erased in 0.375 s
Area [013E0000-013FFFFF] erased in 0.375 s
Area [01480000-0149FFFF] erased in 0.359 s
Area [01C20000-01C3FFFF] erased in 0.375 s
Programming ...
Programming completed.
SpUnlock skipped.
Completed in 55.953 s
Phone Type: RM-298 (Nokia 2630)
SW Version: V 57.20 09-02-09 RM-298 (c) Nokia
Imei plain: 35609700811132-6
Imei OTP: 35606503824372
Product Code: 0585849
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: EJ
Language Pack:
English,Russian,Ukrainian
Imei net: 35609700811132
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Old 02-10-2010, 16:09   #4 (permalink)
uzmantel's Avatar
Member: 163458
Sonork: 100.1606694
Thanks Meter: 503
video here thanx button )
http://forum.gsmhosting.com/vbb/showthread.php?t=919108
Old 02-10-2010, 16:21   #5 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
PhoneType:RM-298
SwVersion: V 06.82 26-09-08 RM-298 (c) Nokia
MCU file: rm298__06.82.mcusw
New Imei: 353121020653314
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
UEM ID: 0001F8CF:3B8ADA60
Area [01000000-0101FFFF] erased in 0.610 s
Area [016C0000-016DFFFF] erased in 0.610 s
Area [013E0000-013FFFFF] erased in 0.610 s
Area [01480000-0149FFFF] erased in 0.625 s
Area [01C20000-01C3FFFF] erased in 0.625 s
Programming ...
Updating SIMLOCK ...OK
Completed in 50.875 s
SW Version: V 06.82 26-09-08 RM-298 (c) Nokia
Imei plain: 35312102065331-4
Imei OTP: 00000000000000
ASIC ID: 0x3162, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35312102065331
Counter: 0/3, 0/10
PROFILE_BITS: 800000000001000B
Old 02-10-2010, 19:13   #6 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
nice shareing dear wounder full job
2630 imei change but no signal vicky784 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-27-2010 09:42
2630 imei chang succesful but no service khanmobiles0003 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 03-24-2010 20:40
NOKIA 2630 imei change???? Ramzan khan Universalbox 5 01-30-2010 12:55
Nokia 2630 after change imei set into contect service Sahil2007 Universalbox 13 02-09-2009 21:31
Page generated in 0.15370 seconds with 10 queries
