02-10-2010, 08:55 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 731314 Status: Offline Sonork: 100.1591813 Thanks Meter: 81 | 6300 Contact Service but Normal Mode OK This is BUS Check in MX-Key Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 0AE000101E8B7B5604BDB2DB90D905621899AE4E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 0041 - 0000 6A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: 35677702156459 Original Product code: 0559490 Bluetooth ID: 0022FC008E5A Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35677702156459-9 Product Code: 0537631 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-11-13T15:58:29Z SW Version: 07.21 Variant Version: 018 ProductProfile: RM217_0537631_07.21_018.spr Simlock: 0537631_simlock.bin Imei net: 356777021564599 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to golam_maula For This Useful Post: |
02-10-2010, 09:08 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | try to change Clock cristal,RETU and thahvo one by one good luck |
The Following User Says Thank You to VIBINDAS_INDIA For This Useful Post: |
02-10-2010, 09:11 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Bsi Line might be out of order. HW issue. Can't be repaired with sw. Br, Umair |
The Following 3 Users Say Thank You to Umair Rashid For This Useful Post: |
02-10-2010, 09:55 | #7 (permalink) |
Banned Join Date: Mar 2006
Member: 239004 Status: Offline Sonork: 100.1589817 Thanks Meter: 388 | its hardware my bro its not software ... try to change cristel ... or check bsi line ... |
The Following User Says Thank You to waqas_ali601200 For This Useful Post: |
02-10-2010, 16:23 | #14 (permalink) |
Member: 731314 Status: Offline Sonork: 100.1591813 Thanks Meter: 81 | Phone Type: RM-217 SW version: V 07.30 07-05-09 RM-217 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y !NO SIGNAL(06) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
1200 flash ok ui setting ok normal mode ok but not no by power switch switch volt ok | Punit Kumar | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 02-25-2010 12:58 |
1200 ,1208,1209 no power on with bettary But Normal mode ok | Dooha_Bd | Nokia Hardware & Hardware Repair | 8 | 02-12-2010 21:09 |
1208 normal mode ok but show contact service | tiju kkm | Nokia Hardware & Hardware Repair | 5 | 11-22-2008 17:02 |
N70 using Fbus cable local mode,normal mode ok,flashing ok...but could not power on | denadio | Nokia Hardware & Hardware Repair | 3 | 07-16-2008 21:17 |
1600 fleshing ok local mode/test mode ok but normal mode fail | zargar322 | Nokia Hardware & Hardware Repair | 9 | 03-31-2008 16:22 |
