Old 03-26-2010, 12:17   #1 (permalink)
mobileZONE's Avatar
Member: 125401
Thanks Meter: 22
6300 dead after flash 6233 dead after flash
Version from phone: 05.00
Version from file: 07.30
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1280000A02186C5686F2A4B5464F968F14A3DC9E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35805201754606
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_35805201754606_BA CK.rpl"
Processing file: rm217__07.30.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-0031FFFF]
CMT NOR area [00320000-0105FFFF]
CMT NOR area [01060000-01067FFF]
CMT NOR area [01068000-0107FFFF]
erased in 44.219 s
Flash programming ...
CMT PAPUBKEYS: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 (RAP Certificate 52 v1) written.
Programming completed in 12 min 1.734 s
Processing file: rm217__07.30.ppm_r as PPM
[BB5,BB5 ALGORITHM] size: 5.14 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.50 MB
CMT NOR area [01080000-015FFFFF]
erased in 12.954 s
Programming completed in 4 min 23.078 s
file rm217__07.30_sd_ctv_prc_512_v2.fpsimage is empty, skipped.
Processing file: rm217__07.30.image_ctv_cn as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 4.57 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 9.87 MB
CMT NOR area [01600000-01FDFFFF]
erased in 29.281 s
Converting UCP blocks to 128 K.
Programming completed in 3 min 53.578 s
Flashing completed in 26 min 9.906 s
Phone not responding !
Total time to process is 26 min 58.688 s
This is the log from the 6300 running latest update... flashed with prevous versions without any problems...
6233 exactly the same @ the end and now both dead
Old 03-26-2010, 12:32   #2 (permalink)
Member: 239004
Sonork: 100.1589817
Thanks Meter: 388
use usb cable for flash and then post log here
Old 03-26-2010, 23:18   #3 (permalink)
mobileZONE's Avatar
Member: 125401
Thanks Meter: 22
I uninstalled latest update and re installed v1.6 re flashed and is working fine... What i did notice in v1.7 is my jaf was being called POTATO BOX INTERFACE in v1.6 its being called JAF INTERFACE im also getting more sucess unlocking dct4+
Old 03-27-2010, 00:35   #4 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro,try to use ufs INTERFACE
Old 03-27-2010, 01:17   #5 (permalink)
ferdie1969's Avatar
Member: 883572
Thanks Meter: 63
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
erased in 44.219 s
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.50 MB
erased in 12.954 s
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 9.87 MB
erased in 29.281 s
i had same problem when i flash 6288 phone not responding after flash. so i flash it again n i thick fast flash it it revive it.
Gx25 After Flash Still Dead Nasmi Sharp 17 04-20-2007 10:55
6233 auto off/ after flash error dead!! help! watari31 Nokia Base Band 5 ( BB-5 ) 1 01-01-2007 11:46
Page generated in 0.31638 seconds with 8 queries
