Old 02-10-2010, 08:04   #1 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
6300 SD corrupt
here is log
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35640------------
Product Code: 0537630
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35640-------------
Version: SIMLOCK SERVER VERSION 63
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 8000000000000000
BLOCK 1: 1=OPEN, DATA=00101F
after tht i repair SD
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.21 05-11-08 RM-217 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 5.093 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-217_35640101_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-10-2010, 08:52   #2 (permalink)
Cyclone Team<3's Avatar
Member: 1212935
Sonork: cylone team
Thanks Meter: 122
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
You got Only NPC? NO PROBLEMO!
Old 02-10-2010, 08:54   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
SUPERDONGLE repair step
Repair SUPERDONGLE
br,
Old 02-10-2010, 09:58   #4 (permalink)
mali_comm's Avatar
Member: 1145301
Thanks Meter: 116
sir i try 2 repar SD sd repair successfull but i try 2 write pm file . no sucess dnt knw how 2 write without 308 . now my phone on Contact Service here is LOG
Imei plain: 35640101135502-1
Product Code: 0538334
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356401011355021
Counter: 0/3, 0/10
Old 02-10-2010, 10:01   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
THEN
1.do SX-4 and write PM without [308] area
in case after Superdongle repair , please use "SUPER SD Auth"
2.Check BB5 Secure Validation
[MXKEY - INFO] !!! NEW magic button inside mxkey !!!
this is have important info, where the real problem
3.do "Recover CERT" , if doesn't work
Begin Certificate Request ...
Connecting to server ...OK, Login ...
ERROR: No certificate found in the database !
check this
Just in case if Recovery via Server doesn't work.......
need more file about CCC,HWC and VARIANT
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
6300 sd repair missing npc data! sancakaziz MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-03-2010 14:39
6300 sd help me singhdeep MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-01-2010 08:39
6300 SD Repair Done But??? gravity06 Universalbox 18 01-24-2010 11:29
can i repair 6300 sd in cyclone box??? jonymahmud Cyclonebox 2 01-03-2010 15:36
Mini SD corrupted in n73 Help Lovejed Nokia Multimedia 2 12-20-2006 02:06
Page generated in 0.25390 seconds with 8 queries
