01-14-2011, 14:26 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | 6300 security test fail if not success see here 6300 security test fail solution by gsmzaman if you are fail to write pm 1 and 309 and normal procedures advised by all seniors backup rpl all sections with mxkey read pm and save manual flash phone with "" BB5Erase_32MBrap"" file instead of mcu with jaf flash the phone with original procut files on fbus...product code can be read from the back lable of the phone after flash with factroy set you will find the imei 12345610654321? now your phone shoould power ON here if donot power ON again flash with these files. now phone is ON with imei 12345610654321? disconnect the phone and connect it with mxkey click buscheck,,,,,,,you will found her all tests falil her you will restor imei imei with ok now and other certificates are seems fails and security test may pass repair sd now if not success once try again and agian with repair sd now security test will seem fail now load PM file with only 1 and 309 files...... press super sd auth now you will be success with writing pm field 1 and 309 which was difficult before here now secuty test is pass sd is pass but sim lock is curuppted now press update splock and finally facoty set realy this is finilize by me after a very hard job befor i posted to many time in the forum but no authenticated answer this is done by me and now i request to mx key that finilized in a proper way when i try to erase this with mx key why i did not success..and why the jaf was able to erase and flahs that phone and mxkey was unable to flash after erase and my procedure adopted by me is not a certified procedur but i success with this. requested mxkey to examin this procedur and bring in a manner to understand easily... thanks to you all by gsmzaman |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
