Old 05-08-2010, 16:56   #1 (permalink)
Member: 1015645
Thanks Meter: 114
6300 set after flash problem mxkey
i have got 6300 set calculater remove when i flash it version 7.30 before version 5.50 after flash complete but i want to language arbic not this version 7.30 plz help me mxkey team master but flash with version 7.21 present in arabic version so after flash this version 7.21 nokia show and off plz solution want
The Following User Says Thank You to zeedan For This Useful Post:
Old 05-08-2010, 17:09   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Bro youre flashing with wrong firmware, 7.30 is for chinese market only, you wont find arabic language for this version. If you already flash with 7.30 and flash again with 7.21, that means downgrading, that is why it shows Nokia logo then shut down. if you check it using HWK or mx key, you will know that it wont enter into local mode or test mode ..etc. The solution is you better stick with 7.30 or if you need arabic language badly, then flash it using ENO firmware and after that, flash it with 7.20 again. Check out the sticky thread on how to use ENO firmware and where to get it.
BR,
curvenger
Old 05-08-2010, 20:02   #3 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
if not work try this
mxkey>serves>quick fix>bb5 sw downgrade fix and clickdo job
Old 05-09-2010, 08:46   #4 (permalink)
Member: 1015645
Thanks Meter: 114
bro help me
BR,
curvenger
plz give me good link of eno firamware ..............................
Old 05-09-2010, 18:23   #5 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
If you install the firmware from Data Packages, its already there, its inside the RM-217 folder .. i.e C:\Program Files\Nokia\Phoenix\Products\RM-217, the name will be like rm217__07.21.image_telenor_rs or rm217__07.21.image_telenor_no_black etc, if you have UFS, there is a separate ENO fields in the new version 2.1.0.x. Using another tool(e.g MxKey), select ENO file in the MCU field and flash it, after that full flash again with your desired firmware. I hope you understand what i mean right?
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.15006 seconds with 9 queries
