03-13-2010, 21:59 | #1 (permalink) |
Insane Poster Join Date: Sep 2007 Location: Venezuela
Member: 595054 Status: Offline Thanks Meter: 4 | 6300 whit imei 12345654321? after load original RPL It had to do a frequency change in the cel, from Digitel to Movistar. So far so good. But he gave me the curiosity of charging an RPL of a 5220 digitel with fields that are CCC_DATA and HWC_DATA which comes of course must be changed I will suggest that's what I did step by step and where I go. 1. In MX-Key scan 2. Backup of PM 3. Backup of RPL 4. Service Tab> Imei & Security> Imei rebuild> write rpl (RPL of 5220 with CCC_DATA fields and HWC_DATA) RPL load and execute but at the final line of the log show me this error. Invalid Pointer error 5. Service Tab> Action> Phone info run. Log Version Info: MCU SW version: V 05.00 27-04-07 RM-217 © Nokia. HW version: 4001 RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.00 27-04-07 RM-217 © Nokia. L BT MCM version: 06CC-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: Digitel Venezuela V 2.0 03-05-07 RM-217 © Nokia. Product Info: Production serial number: 7I0355400 Product code: 0531179 Module code: 0203166 Basic production code: 0537040 Serial Numbers: IMEI plain: 3548260107xxxxx IMEI spare to net: 3A 45 28 06 01 27 41 09 IMEI SV to net: 33 45 28 06 01 27 41 09 F8 Other Info: Model: Nokia 6300 (Classic Phone) CS type: GSM850/GSM900/GSM1800/GSM1900 BSI: 4,3 KOhm Imei net: 3548260107xxxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0 / 3, 0 / 10 CONFIG_DATA: 7340200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1 = OPEN, DATA = 73402F BLOCK 2: 1 = OPEN, DATA = 73403F BLOCK 3: 1 = OPEN, DATA = 73401F __________________________________________________ _______________________________ 6. Flash Tab> check bus log Phone Type: RM-217 (Nokia 6300) SW Version: V 05.00 27-04-07 RM-217 © Nokia. Imei plain: 3548260107xxxxx Product Code: 0531179 Language Pack: - Not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3548260107xxxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0 / 3, 0 / 10 CONFIG_DATA: 7340200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1 = OPEN, DATA = 73402F BLOCK 2: 1 = OPEN, DATA = 73403F BLOCK 3: 1 = OPEN, DATA = 73401F Ok after show me ST failed. I did was load the RPL original of the cel but modified only whit the fields CCC_DATA and HWC_DATA . Was all that was changed initially to give me this error. I make again the same procedure in steps 4,5 and 6 I notice that in step 5 info of the cel continues to maintain the 4 bands (in the process of uploading RPL told me that it had succeeded.) Continues with ST failed I decided to load the full original backup. Step 4 Log Imei: 3548260107xxxxx Restoring RF / BB DATA from backup ... RAP Data: SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM see: 1.1] EM0 ID: 00,000,232 EM1 ID: 00,000,353 PUBLIC ID: 180002180146005266ED62BDFD0B7EC95B0E624E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208-0000 6921 [Samsung K8F5615ETM, 256 Mbits] type: NOR, RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Erasing CMT NPC ... OK RF Updating ... OK BB Updating ... OK Updating WARRANTY ... OK Updating PROD ... OK BT Updating ... OK RAP Data: SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM see: 1.1] EM0 ID: 00,000,232 EM1 ID: 00,000,353 PUBLIC ID: 180002180146005266ED62BDFD0B7EC95B0E624E ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 2208-0000 6921 [Samsung K8F5615ETM, 256 Mbits] type: NOR, RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 NPC verified Ok. Updating ... OK CMT NPC Updating ... OK CMT CCC Updating ... OK CMT HWC Updating ProductCode (0531179) ... OK Updating PSN (7I0355400) ... OK Updating HWID (4001) ... OK Updating LOCK ... OK Updating ... OK WMDRM_PD Certificate programmed successfully! Phone Type: RM-217 (Nokia 6300) SW Version: V 05.00 27-04-07 RM-217 © Nokia. Imei plain: 12345610654321 -? Product Code: 0531179 Language Pack: - Not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid! Net Imei: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0 / 3, 0 / 10 CONFIG_DATA: 7340200000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1 = OPEN, DATA = 73402F BLOCK 2: 1 = OPEN, DATA = 73403F BLOCK 3: 1 = OPEN, DATA = 73401F Now solve the ST failed, but I put in the imei 12345654321? blink.gif There are ways to solve it? or, I have to buy new phone for the customer? Last edited by suarezfco; 03-13-2010 at 22:07. |
03-13-2010, 22:05 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | bro do u have backup rpl? if u have open with notebad and copy then poste here |
The Following User Says Thank You to alasmmar For This Useful Post: |
03-13-2010, 22:13 | #3 (permalink) | |
Member: 595054 Status: Offline Thanks Meter: 4 | Quote:
[CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0531179 PSN=7I0355400 HWID=4001 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533313137394300000000 NPC_DATA_2=0000000000000000000000005444E09449CA1E4 750610300646F7242000000001800021801460052 NPC_DATA_3=66ED62BDFD0B7EC95B0E624E7F7E6491E8D3049 4B45630BB3A8599F4E1C674C9E14679CF3D834616 NPC_DATA_4=F21D419778A62D8CA4FFB633000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3345280601274169FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=2D9E7BDC1A00000000000000000000000000000 00000000000000000000000001960BD2AD87FE9D5 NPC_DATA_7=22BB18685EC9583B7683534CEBD0D488367C625 3DEEE95012510BB3E74C9296670A1937C53E8CBC8 NPC_DATA_8=7FD01EC28FF6D19F77B90B575CB671EC6CBE5EA 0F7CDBD37A53E1E2FEAC431F4A9AC664C6EF699BE NPC_DATA_9=78ACBB7EA98DEFB3101BF5CEE114F8F0DFF807E 362A4E72E3C6561CA09615D20A19378756AAE2E10 CCC_DATA_1=4343434302004150010000009138E0949BF0414 6DC432200A5039B00000060010000000000000000 CCC_DATA_2=000000000000000000000000000000000000000 00000000000000000000000003035333131373943 CCC_DATA_3=C7C248450000000000000000010000000E00000 00000000000000000000000000000000000000000 CCC_DATA_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 CCC_DATA_6=000000000000000000000000000000000000000 0000000004993594DDF962A38F3F6BC1ABCB5F1C3 CCC_DATA_7=154F0675F4172880E995A182E798278ACB63103 BEDB43F62E4C347FF9D953DD2921FAFFC960A1252 CCC_DATA_8=90BBD8F9484184DC119F6FF7A6AAD3EDF935B75 67C7AB22ECC20CD25DE6D66D6346A9B2F256C775F CCC_DATA_9=37BFAC519C2D15115F42876F302DD3CFFB1B06F C853934D77E7C38CAE366FF15 HWC_DATA_1=4348574305004150010000005444E0944ACA1E4 70000000000000000000000000000000000000000 HWC_DATA_2=0000000000000000180002180146005266ED62B DFD0B7EC95B0E624E303533313137394300000000 HWC_DATA_3=000000006A096783B5C907906FA6C8AB24630D1 B76C36ECF018077896CE6BDF123340AB756A5C215 HWC_DATA_4=AA3BE9005FB58E9B46C6B29107E23D2EABE8617 7DD7F8E033DF581C9E64CCE8C912D390DD6D3AE5A HWC_DATA_5=6AB0E231FC9C41538207167C31E2EACAA7BD49A F46957FBA9E06EC2C64302717538FB5D5DC1B0681 HWC_DATA_6=BA75C55F84C19481CE8A28D4 WMDRM_PD_DATA_1=261300003C004400450056004300450052 0054002000760065007200730069006F006E003D002200 WMDRM_PD_DATA_2=31002E00300022003E003C004300450052 0054004900460049004300410054004500200074007900 WMDRM_PD_DATA_3=700065003D002200440045005600490043 00450022003E003C0044004100540041003E003C005500 WMDRM_PD_DATA_4=4E00490051005500450049004400200070 007200690076006100740065003D002200310022003E00 WMDRM_PD_DATA_5=4700410041004300470041004600470041 0046004A006D00370057004B0039002F00510074002B00 WMDRM_PD_DATA_6=7900560073004F0059006B0034003D003C 002F0055004E004900510055004500490044003E003C00 WMDRM_PD_DATA_7=5000550042004C00490043004B00450059 00200070007200690076006100740065003D0022003100 WMDRM_PD_DATA_8=22003E00680057006D0037007900770038 006A002F007400490035007A0062006D002B0058006200 WMDRM_PD_DATA_9=350062006B0065004C00750039006E0033 007600790063005700560058006F0055004F0061007900 WMDRM_PD_DATA_10=69004F0063005A0032007800300074006 E00360047004F006C0074004A0041003D003D003C002F00 WMDRM_PD_DATA_11=5000550042004C00490043004B0045005 9003E003C004B004500590044004100540041003E003C00 WMDRM_PD_DATA_12=2F004B004500590044004100540041003 E003C002F0044004100540041003E003C004D0053004400 WMDRM_PD_DATA_13=52004D005F005300490047004E0041005 4005500520045005F00560041004C00550045003E004A00 WMDRM_PD_DATA_14=710036005A005A0074006E004C005A007 6004500450074006C0078006B0079005800460038005000 WMDRM_PD_DATA_15=79007A00340032006B0031002B0038004 80048004B0030006C00590078002B004D002F0046007800 WMDRM_PD_DATA_16=530075004E00620072006F002B0041004 90077004F004E0077003D003D003C002F004D0053004400 WMDRM_PD_DATA_17=52004D005F005300490047004E0041005 4005500520045005F00560041004C00550045003E003C00 WMDRM_PD_DATA_18=530059004D005300490047004E0041005 4005500520045003E003C002F00530059004D0053004900 WMDRM_PD_DATA_19=47004E00410054005500520045003E003 C002F004300450052005400490046004900430041005400 WMDRM_PD_DATA_20=45003E003C00460041004C004C0042004 10043004B003E003C005300450043005500520049005400 WMDRM_PD_DATA_21=5900560045005200530049004F004E003 E0032002E0034002E003100300036002E00310036003100 WMDRM_PD_DATA_22=3C002F005300450043005500520049005 4005900560045005200530049004F004E003E003C004300 WMDRM_PD_DATA_23=450052005400490046004900430041005 4004500200070007200690076006100740065003D002200 WMDRM_PD_DATA_24=310022003E00680057006D00370079007 70038006A002F007400490035007A0062006D002B005800 WMDRM_PD_DATA_25=6200350062006B0065004C00750039006 E0033007600790063005700560058006F0055004F006100 WMDRM_PD_DATA_26=790069004F0063005A003200780030007 4006E00360047004F006C0074004A004100490045006100 WMDRM_PD_DATA_27=7100450031004B006A006F00550056007 3006300420042004D004F0070006300630030006D006200 WMDRM_PD_DATA_28=630041006400340035006600390058004 A00570038004B007700510067006F0073004E006E007A00 WMDRM_PD_DATA_29=4300410043002F0051006100780037005 10054004600310059006C0061003C002F00430045005200 WMDRM_PD_DATA_30=540049004600490043004100540045003 E003C002F00460041004C004C004200410043004B003E00 WMDRM_PD_DATA_31=3C0043004500520054004900460049004 300410054004500200074007900700065003D0022004700 WMDRM_PD_DATA_32=52004F005500500022003E003C0044004 100540041003E003C004E0041004D0045003E0036003300 WMDRM_PD_DATA_33=300030003C002F004E0041004D0045003 E0020000D000A0020002000200020003C004D0041004E00 WMDRM_PD_DATA_34=550046004100430054005500520045005 2003E004E006F006B00690061003C002F004D0041004E00 WMDRM_PD_DATA_35=550046004100430054005500520045005 2003E0020000D000A0020002000200020003C004D004100 WMDRM_PD_DATA_36=4B0045003E004E006F006B00690061003 C002F004D0041004B0045003E0020000D000A0020002000 WMDRM_PD_DATA_37=200020003C00440049005300540052004 9004200550054004F0052003E004E006F006B0069006100 WMDRM_PD_DATA_38=3C002F004400490053005400520049004 200550054004F0052003E0020000D000A00200020002000 WMDRM_PD_DATA_39=20003C004D004F00440045004C003E005 2004D002D003200310037003C002F004D004F0044004500 WMDRM_PD_DATA_40=4C003E0020000D000A002000200020002 0003C00530045004300550052004900540059004C004500 WMDRM_PD_DATA_41=560045004C003E0032003000300030003 C002F00530045004300550052004900540059004C004500 WMDRM_PD_DATA_42=560045004C003E0020000D000A0020002 000200020003C0048004100520044005700410052004500 WMDRM_PD_DATA_43=5F005600450052005F004D0041004A004 F0052003E0031003C002F00480041005200440057004100 WMDRM_PD_DATA_44=520045005F005600450052005F004D004 1004A004F0052003E0020000D000A002000200020002000 WMDRM_PD_DATA_45=3C0048004100520044005700410052004 5005F005600450052005F004D0049004E004F0052003E00 WMDRM_PD_DATA_46=30003C002F00480041005200440057004 100520045005F005600450052005F004D0049004E004F00 WMDRM_PD_DATA_47=52003E0020000D000A002000200020002 0003C004600490052004D0057004100520045005F005600 WMDRM_PD_DATA_48=450052005F004D0041004A004F0052003 E0031003C002F004600490052004D005700410052004500 WMDRM_PD_DATA_49=5F005600450052005F004D0041004A004 F0052003E0020000D000A0020002000200020003C004600 WMDRM_PD_DATA_50=490052004D0057004100520045005F005 600450052005F004D0049004E004F0052003E0030003C00 WMDRM_PD_DATA_51=2F004600490052004D005700410052004 5005F005600450052005F004D0049004E004F0052003E00 WMDRM_PD_DATA_52=20000D000A0020002000200020003C004 60045004100540055005200450053003E000D000A002000 WMDRM_PD_DATA_53=20002000200020002000200020003C004 3004C004F0043004B003E0032003C002F0043004C004F00 WMDRM_PD_DATA_54=43004B003E0020000D000A00200020002 00020002000200020002000200020002000200020003C00 WMDRM_PD_DATA_55=53004500430055005200450043004C004 F0043004B003E0020000D000A0020002000200020002000 WMDRM_PD_DATA_56=200020002000200020002000200020002 000200020003C00550052004C003E006800740074007000 WMDRM_PD_DATA_57=3A002F002F0067006F002E006D0069006 30072006F0073006F00660074002E0063006F006D002F00 WMDRM_PD_DATA_58=660077006C0069006E006B002F003F004 C0069006E006B00490064003D0032003500380031003700 WMDRM_PD_DATA_59=3C002F00550052004C003E0020000D000 A0020002000200020002000200020002000200020002000 WMDRM_PD_DATA_60=200020002000200020003C00500055004 2004C00490043004B00450059003E00210043004E006800 WMDRM_PD_DATA_61=760076007A003100570061004E0056003 1004100460055006D006500740078006B0076006D003900 WMDRM_PD_DATA_62=690044003400550072004500390063006 E004700550069002100710063007100640078004D006900 WMDRM_PD_DATA_63=58006D00440031002A0069006B0059004 70041003D003D003C002F005000550042004C0049004300 WMDRM_PD_DATA_64=4B00450059003E0020000D000A0020002 00020002000200020002000200020002000200020003C00 WMDRM_PD_DATA_65=2F0053004500430055005200450043004 C004F0043004B003E0020000D000A002000200020002000 WMDRM_PD_DATA_66=20002000200020003C004D00450054004 500520049004E0047003E0031003C002F004D0045005400 WMDRM_PD_DATA_67=4500520049004E0047003E0020000D000 A00200020002000200020002000200020003C004C004900 WMDRM_PD_DATA_68=430045004E00530045005F00410043005 1003E0030003C002F004C004900430045004E0053004500 WMDRM_PD_DATA_69=5F004100430051003E0020000D000A002 00020002000200020002000200020003C004C0049004300 WMDRM_PD_DATA_70=45004E00530045005F00530059004E004 3003E0031003C002F004C004900430045004E0053004500 WMDRM_PD_DATA_71=5F00530059004E0043003E0020000D000 A00200020002000200020002000200020003C0045004E00 WMDRM_PD_DATA_72=4300520059005000540049004F004E003 E0031003C002F0045004E00430052005900500054004900 WMDRM_PD_DATA_73=4F004E003E0020000D000A00200020002 000200020002000200020003C00530059004D004D004500 WMDRM_PD_DATA_74=54005200490043005F004F00500054003 E0031003C002F00530059004D004D004500540052004900 WMDRM_PD_DATA_75=43005F004F00500054003E0020000D000 A0020002000200020003C002F0046004500410054005500 WMDRM_PD_DATA_76=5200450053003E000D000A00200020002 00020003C004C0049004D004900540053003E000D000A00 WMDRM_PD_DATA_77=200020002000200020002000200020003 C004D004100580043004800410049004E00440045005000 WMDRM_PD_DATA_78=540048003E0032003C002F004D0041005 80043004800410049004E00440045005000540048003E00 WMDRM_PD_DATA_79=20000D000A00200020002000200020002 000200020003C004D00410058004C004900430045004E00 WMDRM_PD_DATA_80=53004500530049005A0045003E0031003 0003200340030003C002F004D00410058004C0049004300 WMDRM_PD_DATA_81=45004E0053004500530049005A0045003 E0020000D000A0020002000200020002000200020002000 WMDRM_PD_DATA_82=3C004D004100580048004500410044004 5005200530049005A0045003E0035003100320030003C00 WMDRM_PD_DATA_83=2F004D004100580048004500410044004 5005200530049005A0045003E0020000D000A0020002000 WMDRM_PD_DATA_84=200020003C002F004C0049004D0049005 40053003E003C005000550042004C00490043004B004500 WMDRM_PD_DATA_85=59003E00560037002B006A0044006D004 6005000360044006E006D005A0049007A00460067006800 WMDRM_PD_DATA_86=790074006A00300072006A004F0032006 30072007700440066004F0069005200510052006F005700 WMDRM_PD_DATA_87=6800490072004C00770064004C0070004 70066006A005400500079004F0077003D003D003C002F00 WMDRM_PD_DATA_88=5000550042004C00490043004B0045005 9003E003C002F0044004100540041003E003C004D005300 WMDRM_PD_DATA_89=440052004D005F005300490047004E004 10054005500520045005F00560041004C00550045003E00 WMDRM_PD_DATA_90=520054004900320053002B00740034004 C00640033006C005A006800310066007100670069003300 WMDRM_PD_DATA_91=370046007400370067006E00730053006 A0059006C00460030004E004200650053002F0079004C00 WMDRM_PD_DATA_92=6B0042005800320058004E00390031004 F006A0067003700470077003D003D003C002F004D005300 WMDRM_PD_DATA_93=440052004D005F005300490047004E004 10054005500520045005F00560041004C00550045003E00 WMDRM_PD_DATA_94=3C002F004300450052005400490046004 90043004100540045003E003C0043004500520054004900 WMDRM_PD_DATA_95=460049004300410054004500200074007 900700065003D00220041005500540048004F0052004900 WMDRM_PD_DATA_96=5A004100540049004F004E0022003E003 C0044004100540041003E003C0053004500430055005200 WMDRM_PD_DATA_97=4900540059004C004500560045004C003 E0032003000300030003C002F0053004500430055005200 WMDRM_PD_DATA_98=4900540059004C004500560045004C003 E003C0041005500540048005F00490044003E0031003500 WMDRM_PD_DATA_99=340031003C002F0041005500540048005 F00490044003E003C005000550042004C00490043004B00 WMDRM_PD_DATA_100=450059003E0043007A00520071005800 62005400320047006E0075006B00510053006C0052007700 WMDRM_PD_DATA_101=55007400540075002B0069006F005000 44004C0032004B005300390036004E004900530046003200 WMDRM_PD_DATA_102=72004600340077007200430055005700 61006A00640067006A00430034004E0077003D003D003C00 WMDRM_PD_DATA_103=2F005000550042004C00490043004B00 450059003E003C002F0044004100540041003E003C004D00 WMDRM_PD_DATA_104=5300440052004D005F00530049004700 4E00410054005500520045005F00560041004C0055004500 WMDRM_PD_DATA_105=3E00330079004F005600410050003800 710036004A004400460050004D0070005200420058002F00 WMDRM_PD_DATA_106=57006700490032006600690054007800 41004F0037003400320055006F005A006700480075004700 WMDRM_PD_DATA_107=79003500620034006C00650063004900 7100700057006B006500460067003D003D003C002F004D00 WMDRM_PD_DATA_108=5300440052004D005F00530049004700 4E00410054005500520045005F00560041004C0055004500 WMDRM_PD_DATA_109=3E003C002F0043004500520054004900 4600490043004100540045003E003C004300450052005400 WMDRM_PD_DATA_110=49004600490043004100540045002000 74007900700065003D00220041005500540048004F005200 WMDRM_PD_DATA_111=49005A004100540049004F004E005F00 52004F004F00540022003E003C0044004100540041003E00 WMDRM_PD_DATA_112=3C0041005500540048005F0049004400 3E0031003C002F0041005500540048005F00490044003E00 WMDRM_PD_DATA_113=3C005000550042004C00490043004B00 450059003E00610031007400330068007800720067002100 WMDRM_PD_DATA_114=710062004F0067006B0074006E006200 590061004500450069003400740065004300730065002100 WMDRM_PD_DATA_115=67007A00360052007600540050007500 430021007A0069007A004B004A006C007000550037007800 WMDRM_PD_DATA_116=6F0064007500530077003D003D003C00 2F005000550042004C00490043004B00450059003E003C00 WMDRM_PD_DATA_117=2F0044004100540041003E003C004D00 5300440052004D005F005300490047004E00410054005500 WMDRM_PD_DATA_118=520045005F00560041004C0055004500 3E002F006C006A0046006B007A004B00320079007A003500 WMDRM_PD_DATA_119=37003900480051006D00420033005100 79003500780066004E006700440070006900390065005800 WMDRM_PD_DATA_120=520049004100410075006B0056007700 35002B0030003700370042006400630069004B0042005000 WMDRM_PD_DATA_121=3300490077003D003D003C002F004D00 5300440052004D005F005300490047004E00410054005500 WMDRM_PD_DATA_122=520045005F00560041004C0055004500 3E003C002F00430045005200540049004600490043004100 WMDRM_PD_DATA_123=540045003E003C002F00440045005600 43004500520054003E00 CHECKSUM=-1 [CERT_PROG_DATA_OUT_APE] PRODUCTCODE=0531179 PSN=7I0355400 HWID=4001 CHECKSUM=-1 [MISC_PROG_DATA_OUT] RF_DATA_1=0001000C000000721B4800000000000000000000 0000000000000000000000000000000000000002 RF_DATA_2=00050015003300040007FFD7FFDCFFE900000000 0000000000000000000000000000000000000000 RF_DATA_3=0000000000000000000000000000000000000000 000000000000000000000000000000000000FFE8 RF_DATA_4=007600020062FFA6FF9D40004005FE5300700000 247A247A247A247A1FFF1C2818F51709147A128F RF_DATA_5=11470FFF0EB80E140CCC0C280B840AE1247A247A 247A25A420711BB9180D152B12DC10F80F5C0E02 RF_DATA_6=0CC80BC30ABF09F1092D088E00071CD200071CD2 00071CD20004006E1B1B00000000000000000000 RF_DATA_7=0000000000000000000000000000000000000003 000C000E002D000FFFF9FFF2FFF3FFED00000000 RF_DATA_8=0000000000000000000000000000000000000000 0000000000000000000000000000000000000000 RF_DATA_9=0000000000000000000000000000000000000006 0062008B00003F44404B0629005D0000247A1EB7 RF_DATA_10=1AE017AD151E128F11470F5B0E140D700C280B8 40AE10A3D0A3D099909990999281B1E4D199D1602 RF_DATA_11=130F10B20EE50D520C000AE409F4091B088D080 4079107210999099900011FCF00011FCF00011FCF RF_DATA_12=0008006E1AF3000000000000000000000000000 00000000000000000000000000000000300350046 RF_DATA_13=003800070014FFF7FFDBFFAC000000000000000 00000000000000000000000000000000000000000 RF_DATA_14=000000000000000000000000000000000000000 00000000000000000000000000000000D00620094 RF_DATA_15=000D3F44403E059900610000247A1EB71AE0185 115C2133211EB0FFF0EB80E140CCC0C280B840AE1 RF_DATA_16=0AE10A3D0A3D0A3D26A91DB3195415E7131510C 60F1C0D9C0C4C0B2E0A38096708D2085007D00765 RF_DATA_17=0A3D0A3D00021C7400021C7400021C740010005 6FFA6FF9D40004005FE53007200001A3D1A3D1A3D RF_DATA_18=1A3D1A3D1A3D1A3D185115C213D6128F10A30F5 B0EB80D700CCC0C280B841A3D1A3D1A3D1A3D1A3D RF_DATA_19=1A3D1A9317EF151612B910BB0EEE0D7C0C400B3 60A3C096E08BD00120056008B00003F44404B0629 RF_DATA_20=006300001AE01AE01AE01851166613D611EB10A 30F5B0E140D700C280B840B840AE10A3D0A3D0A3D RF_DATA_21=1AE01AE01BD818CF1511124C10110E5F0CE20BB 10AA909BD091E08890804078B0A3D0A3D00140056 RF_DATA_22=0094000D3F44403E0599006600001AE01AE01AE 018511666147A128F11470FFF0EB80E140CCC0C28 RF_DATA_23=0C280B840AE10AE10AE11AE01AE01BE81864154 21275104A0E9C0D150BEA0AEF0A0B096F08E00850 RF_DATA_24=07CE0AE10AE10019000401CD000D001D0006000 10000000300220050000301E10000000000000000 RF_DATA_25=00000000000000000000050300080019021419E 70503000D001901A90BB20502000D0016020F096B RF_DATA_26=0502000D001601A30EBE0000000000000000000 00000000000000000 WARRANTY_DATA_1=00020001000001B000000000720037F420 6D00700072007300740075007700780079007A007C00FF WARRANTY_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF WARRANTY_DATA_3=FF00000000000000000000000000000000 01000000000101000000FFFF0300000000000000501201 WARRANTY_DATA_4=000000000004A804000000000054BA0500 0000000000000000000000000000000000000000000000 WARRANTY_DATA_5=0000000000000000000000000000000000 000000000000000000000000000000030000009302A713 WARRANTY_DATA_6=6414D0030000000000009503FD0D2A08B2 0102000B00000000000000AA0200007F084E129A0FC207 WARRANTY_DATA_7=2DAE4006A1BE00003C0D77092500000000 0000000000000000000000000000009F81010008000000 WARRANTY_DATA_8=0A0000005B0300000000000000000000DD 130000000001006D030000000000000300000000000000 WARRANTY_DATA_9=03000000000000005A000000000000000B 0000000000000000000000000000000000000000000000 WARRANTY_DATA_10=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_11=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 PROD_DATA_1=00040009000000010100010040BF89020C8078 490230A19712BF44FC032A25A80021525015030306 PROD_DATA_2=06082520000103050503430000008164D80832 280A00808100002466000400320600000000000300 PROD_DATA_3=0A374930333535343030000004000830353331 313739000005000830353337303430000006000830 PROD_DATA_4=32303331363600000900053430303100001200 503335343832363031303732313439360055555555 PROD_DATA_5=55555555555555555555555555555555555555 555555555555555555555555555555555555555555 PROD_DATA_6=55555555555555555555555555555555555555 5500130004D7070A01 BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK_DATA_1=01340009000000010300012000300000000000 00000E0000000000000019F815E800000000000000 LOCK_DATA_2=00000000000000000000000000000000000000 000020010000C00000000400000002000000AB0FBD LOCK_DATA_3=96AF2AC271D26264AFDEAD0600914E0B79DD77 F9F716F9CFD25CCACDF1CBF763FD8341C87AC209AF LOCK_DATA_4=915BB5B751429F0C035F7A8B0B5879A6960D42 AC54F22171F7A536E6748A266B6686264B027174EC LOCK_DATA_5=A6E519FF979C6A104F257596B69B2305C096EB 9990CC0CD24B0019F514F66FFFB178FE529E47EB3A LOCK_DATA_6=B89C63A30F9A6301E1B883D72A130D872F8113 058F0303DA4CEBA703AFC6DE6BC0887751D8F3EF25 LOCK_DATA_7=BAEBC3CD25636791EBE1DAB92E7D90E42E10D2 2D8E42EB85A3077770230A29E0399AB7D6726491C3 LOCK_DATA_8=668AC6A6BACB0F975A65D9B3FB8F0BE170CE91 2868D0010000800000000200000002000000AB0FBD LOCK_DATA_9=96AF2AC271D26264AFDEAD0300DCB144335543 86482656246ABC1075DFAD06B12770E519BE8CCB1E LOCK_DATA_10=2409BF75DBDCAF3B84FC7C0D10986DF11E09B 0D2352183CEABFD85D4B7C16B237DAEF3C507BE4F36 LOCK_DATA_11=E9B22F42D0B9593B05DCB3CC99FE503576B9C 81BE52422937CFA867A1340F6ADDF646FEC840323B4 LOCK_DATA_12=FFFD028F00C952B3EC2014D0984BB56477309 B68FEC199B7A8A2AB32C60EA97FA62B415E77D00D00 LOCK_DATA_13=00D00B00000100000002000000AB0FBD96AF2 AC271D26264AFDEAD08001032E0A76C3A01D5818865 LOCK_DATA_14=AA0B650176DE16E2B4713AEB5F9EA4AB8C136 0508865B464D4D5187C5C40B89F34883E05B73EB4EB LOCK_DATA_15=55A9EAC71DB887C9715090B506CE867F3F330 0686673C020062832B84EF0B47386060D255E6215B1 LOCK_DATA_16=6FB6C2D54FAE229A7EDF2411829735F40B0B5 F2112AD7415833988BD6D7E91FD886E5152AA66B3FC LOCK_DATA_17=76926E0114389C715B17BBAAF3CE2FC836C3C 7E04EB6097AA73EF879A52C0DC64ECA63C018840CBA LOCK_DATA_18=C6888850F00E934ADC32EE1CB2804DD7F067C A2549B0B3EBC60432EBB47228C10B59D89F8DDFFF74 LOCK_DATA_19=6BF0A30ABB2F0DCEA2588455591B9DF0613C8 E19071C251F659A318BF86036DA13F35C880D3AE490 LOCK_DATA_20=A35087AD2D31A18B440A55A191D57D81ECA96 A19A1F13167DF800C11BD475BB4905B81217A29242C LOCK_DATA_21=4BE83D0782A3E5ADA0AEE16E727414021BBD4 49E3FC62E8BEB97483DCE9D787F81B7F7D44A05B780 LOCK_DATA_22=240391F6374E7C42E11A2CD104A28814B7AD0 C2789B319FDFF2C28A2330617B2B8D7EEDC2B2EC30D LOCK_DATA_23=A0DEB55A0D850F66599B88187A938B58799DE A2700D5D5E0C0BA48F24BCE92DB298CC753F4AF93A9 LOCK_DATA_24=1838C921744F1DAE474E5B0AB1719EF525BA3 A96360E5426DDFF564106A9E01A49C08AD08E4B097F LOCK_DATA_25=D02DFD5E85DCF1D6F35EBE25D03A6D731B439 5C56A7FE108CC4DECECBDFE6597DCA63F1D8C3F11CA LOCK_DATA_26=08EA8A969A0309E2B87B91A8703FC11A70174 7D35185AB810BA4209339FF435C2A84D87E126253EA LOCK_DATA_27=106480EA2106A48D4BDA5FE8CF1ED7254FA15 AE8A640A0EBBFB1A4E7754B52CAC34440FF89C0DA50 LOCK_DATA_28=7D9D7A7B8FCE713F1C81B30A5E244E95CD7F8 6A00FA759185367E06800D7041BC246904FFE0FBAE2 LOCK_DATA_29=D64488A1CAECB04D53A59B955E9FCA92235C5 E90C7930DE1464810D8432F82CD0F05D47A1F2E62AB LOCK_DATA_30=CF8667F4FF97930718B9AB7D51F7E8309B1E3 F26F6D166A0083ACFEC3459651C0ADBC7DFBA7A77AA LOCK_DATA_31=5F0BCE3B4A8AB4A1FF43B24868037570D4E14 D8E1D05572D9BB41915C2E929872269E8D16098509B LOCK_DATA_32=1CE9CDB6F326229ED479D415A47B35E187BB0 506EE17BF4D840624FF7113DCC89068765F2D03EF73 LOCK_DATA_33=AD21A58773C360A4DDE32C45D0DBE3D6F3E82 490AEDEFC98A114430178814468FA48631DF15AB874 LOCK_DATA_34=6DBC02B173FD86F049F9DB8D6187000D44120 1CE80132B6DAD41071EC7F4F28964143BB6F531638B LOCK_DATA_35=52AF4A127698418318C25B786B1FBE040CB24 50BA8F07934DE613673E32A54628C3A989A054C6D59 LOCK_DATA_36=12679148AAD0B23B5D78F528E0A2698769F3A 61D3D76E4FC79C88C1AE191F80CB3C079F499F81108 LOCK_DATA_37=711E13E8CB28EF4A20549F1AE7B281F176CE9 8A33DCF7B666D003AB1E0C62F8807F549BEA50FE39D LOCK_DATA_38=93862A066AF5C2EC6921FC8408492C85CEED4 A20054010F3EF731376D6EE23BFE1D39093D48E9809 LOCK_DATA_39=E6F4F8FBDED38B77A67779750BDF7E5B51F50 16C3AA1071158F5F11094F01EDF0165508D702E6E2E LOCK_DATA_40=ABA58F9A1A98ECD81A04BED7D33B41366FC03 54CE658BA602D81F70B48D6B53F2F6942B54B3DFB57 LOCK_DATA_41=BAFA0A13D7583C554B677DDDC5DEEAF8BB616 94F4667B478F3BF57DB7E70E9FD277D44201539B9AE LOCK_DATA_42=384AC99DEFD0CA25F0306795ED0C4FA2A2042 8AC3A84947C104812268CE2A64756CD9B9C1C511BA2 LOCK_DATA_43=F6CA6705F2AE1CF3050965793D2A5BDA10AEA 96A759D53FFF5D277F2F3E53753009FFF6820ECD5F3 LOCK_DATA_44=18978D538732C115933E8982BC26E8EC2EC63 CD22DE86B777273B7093C313BD7B52A160790594959 LOCK_DATA_45=6174549C5DBFD7847FE56A4AE4A519F106BDE F3B23766B16F800C1193A356108AAE847E9BE9817C0 LOCK_DATA_46=975A4AC78A4A3A6367F2794423088D311F608 21E998F09DED15DA1159215E3D552653DE317A6D832 LOCK_DATA_47=0BE07E3F8F46E50FA8749F24F7BACF7337498 615E981D9DFE2021B2CC4D720C928AF97BC22C3F946 LOCK_DATA_48=CEAE65B1D8DEC290E2E9CB5B35B4D4203FA45 D462004810C53B25612B8BE9E9B945F3E220E519541 LOCK_DATA_49=F0AF88595BEE9DD885E23F2632C9862B5D8EE 5206C093843FD151654C7F9D7C7BCD030C1A118665F LOCK_DATA_50=9777DC69FCE3A941446B064C5D791880D80EE 81C5F17294B7921D7E4A0C2E4D3F7F1BE5046421975 LOCK_DATA_51=B9F6B7A6DE6DA580AF9B3C238999C3D678D7D 7B1380D0504F55136DB242958BBD4370E618256F804 LOCK_DATA_52=4D172A6E1EC2C6A8736F77494D0B9C16ED3B6 C15C6B7D4E444C1788D0D2F69151E1B0972A1A87D0B LOCK_DATA_53=61F98969CE42E593D2C28DEA32D42F35F94DD 9C0E3A32165316922D47063676B01A09C80DC24A497 LOCK_DATA_54=383D14AAD1616667D72BCBE56558D4C807BB4 7DE2A4AA146C292FE4D9D2B9ABB51557C154B8508C4 LOCK_DATA_55=0FB034018EC160D0EBDAA0F9E92FC2CA20C74 E23F31083628F15A8D078DAB147B2FEB38D1D4EC9D6 LOCK_DATA_56=A0A2CE035AC20FCF6DE3ED3454FC1E8FA5B68 29183D69FEFDE6D54771776FA2FC9A869B1830181EF LOCK_DATA_57=7A11508C491FC2BA0985D5E9BC4F6C87AE7DE 297CDAA5907E8CA54FAC26FFCBF609C5916BFEF2897 LOCK_DATA_58=3D1CC88105E589F407A7487590E1056D96D34 6D5221379F803EE7B7EFDD1E32378323EB06CFAD839 LOCK_DATA_59=BB3F6A169A153C6FC167F49687B3FBD42B510 07221B9E90D0099FB6C5698590D25E781EBD8C817D8 LOCK_DATA_60=266ABEB355372823C4706127A80518B51B27A 7FFE8E21A4A13B419F318A769727ED76E0BA4429247 LOCK_DATA_61=4F9458A6121DA26C8FD04DB1206A2E5F54BC6 D7596757B3A89C1A52CEC4BCBFA031DEEAE63496E7B LOCK_DATA_62=C0585F7E926C5C6BE1B6FCE4093113A5845EF 74C794CAB85D3E40AAE843C01FAD1A2E66989E37CC4 LOCK_DATA_63=CE68C96A75B8F3038CD6DBB34A6A80587D5FD 4B8F87FDFCBB4D0B171B7515888139B64A14621D539 LOCK_DATA_64=ABC41642FD7E6D7535BD9321F2CA3CA8570BA 6F2EA903A9023E019FD2FCE3D307EDDF777537AF8C2 LOCK_DATA_65=F00ECCE1B74D8582F2299B97C424F795DFC36 FB06245B0B46D3C0865A6C71C1FA40E0FC8C2E91B30 LOCK_DATA_66=DF5DEF0558478CE3A84B6AB88E169435EB0B1 145BE8290DEC3DA2A566FADD05A1438BA1E76812A39 LOCK_DATA_67=B9AE6DA703DC6BA5E6D01EB72647EC8365446 F081677F51EA0A34A2EE5D45BC8A436432AD14739C5 LOCK_DATA_68=85EAF2B6326C3D18442DF6C4B8DD057DC1A9A 861EA21BFAFE83859E37BB8C04D651558DB7724EA78 LOCK_DATA_69=488BCA55B83EFD73F219CBA421A63DB65BFAB 06533EAD3361E0165A84EB26125426AA6A8910C7154 LOCK_DATA_70=79270D9840559C015777F14A4D615037E8534 CC29BDBF9B9B84C33029415B2A90806C3AC09B64053 LOCK_DATA_71=86CCEC910CACA0A9CA74445FF1A3CC7E085A3 DC1E0C0ECBFF3D371B87FE7B4366D10AA794CB31EAB LOCK_DATA_72=27D1CBA114AF307030AEDD6E78C59588528FC 9B09AB9AAC5B8FFBACEB11472777180005929D88BC7 LOCK_DATA_73=42C77840B2112E23CAACA2610C5C95645CC2E 243026FD1D696908A52784E80E15BAFB25E18302765 LOCK_DATA_74=21F2C9C2799898975C16596CD4681964A1B8D E22FFA9156C8D502C2EC9B9409C3AE8542C9CDCD8C7 LOCK_DATA_75=9A6C4DD3DEC62E9D7AF38104FDE31D68A7DB4 AB3B7B786F216F74637F892CF21737620577777A647 LOCK_DATA_76=2DD1D5218D0CCC6AFCBFDAAC74A80639036A7 81E9A6213CCBB712957E2AA6E941435AE4C3768EA41 LOCK_DATA_77=D1B4B2973CE70B7B2B2F9F61C1C4BF2B31FFF 247B639F7128C24494A01E6F9B62E63F0FAAD083068 LOCK_DATA_78=1E80D889088EA8835721246163ADB6B5B55E2 A61EA37CC0B0A3CD553C292FA72FE23D0E7FFCA653A LOCK_DATA_79=66F43978FD5963B56F68E7003489A4FFE96DD CE07FC8E63B1452E47A6864A6047F97B3A531ECCAE9 LOCK_DATA_80=864C538F7176CDF3BBD0C35D8E95383FAD053 0487984529D2F5FD7C2C67ED123AA2C7C609CA73638 LOCK_DATA_81=89BF3B33A3C3E8AE99D021B058B9149A9176B 7218CE7FBDD28DD10FBDC3CE69FBDD517A512440C54 LOCK_DATA_82=70D7824114FC1777FA454594BDE3104624BA6 701861DC261E20FDD7E232F2F0FC045E2C2B90B16FB LOCK_DATA_83=DC86AA1EFC5E152B195B3FDEF07E02DA18685 0EE674DB27D747716D78DE3EBD4D8D070251AE4E136 LOCK_DATA_84=D4D011A1DEE62E37456333F74C151162CEE5F 5792C07C113A0778F0F4011D3237C122585A2A33B19 LOCK_DATA_85=095EE1ADD6F377A2B7BDE46493629643D2C08 39F9599D1EDD94C5830F0C069EC01E4C17C586AAF21 LOCK_DATA_86=6E412707C4D16461CE767AC7397CA00C5DC9B B4507737E7B30AF03AFA8B6DE97C1A4439D3A7E5BD4 LOCK_DATA_87=C611CBCD88E6D35F5FB08BD602C96E8CA175D F7E05C0BD5E91E685C9CBAAC3EC1DE115345AF172D0 LOCK_DATA_88=9115C2CF34738A6AD9C7A7EF9040B5D2C87C9 22CCB9B52A32B9CA1D04BDF927B68253063362AD0BC LOCK_DATA_89=DDE58F2D409AA623A1F187010D2427298F82B 7A0A04E8BCCDAD98A962BB00E0000B0000000010000 LOCK_DATA_90=0002000000AB0FBD96AF2AC271D26264AFDEA D0E00E1CFBFCE76918CE3E05FE070937F7FE3441C5E LOCK_DATA_91=3269D84C3F5139B7968966B68D5525EA414D4 94462F13CDC1F245D27FEE1661879E7590BCBF96C00 LOCK_DATA_92=B043271A664B1680C5AB9215145A41A80AFC3 B15DD60473511F01F606593800B20B99AA48DBB235B LOCK_DATA_93=D927C137A78E727525ABAA7CBFFC645023A35 B75E379B688A4A49A6A2AC649B5B63DA11B2A4C828E LOCK_DATA_94=5ACE5869D33E8B1D8A389A11CBCC5E7D3FDB3 72C1D2294D238184A487095AD261A80AE57B9676F03 LOCK_DATA_95=74949F68A4E64B19E92C398FE270110000900 200000300000002000000AB0FBD96AF2AC271D26264 LOCK_DATA_96=AFDEAD070049212D10809FBAD448C4463A93D 752814238BB58867CAB24932508E4A93CCFFA99A3E1 LOCK_DATA_97=D1C186B4364784D8CCA7CD10F4D79250B0BE9 A6CE95E11328A7B9D4418C2A3C57F02E2EC5D4E9EF9 LOCK_DATA_98=4B66DE2324AB9A5F5655A48C88357392C2132 79E6C283613A4DB8F0D162C8D66BB48E4927CF06845 LOCK_DATA_99=E56853F80C95BB389073880CE671A0A7E60CC BBAE89784A584D168D4B7A8F02C81659A419E4EF25E LOCK_DATA_100=B92A87D6B7034B8D74A08BA683A1E9A18BF0 B3931DFE6387472C84803CCC2FE5F414641EFDD1D62D LOCK_DATA_101=F8A75ECF2A4D169F9150061780DD57001014 F37CA28F74FB2597E99CA9855525A54CD753E85C472A LOCK_DATA_102=1C18ABFE4DCD049619DA6C02176A08E65A1B D726EF80B10A2E789DF393FA007BED0DDCE62CBB4537 LOCK_DATA_103=2A7BD72A0A3857A4A484D58C29D5B7DFE557 E18D8CBD1B7C03907BB07D8619992908CA53DE2966C1 LOCK_DATA_104=BC3D7C6DF30DB4376ACA48A12BD7FEC44706 F5D6E65C3CFE282A6F7B11852CE16CC6CFB4FA75C293 LOCK_DATA_105=3313C0B1AC09E0F9414D855CC2D850258BE7 8A3B817A52A8B34924EAEC28F1C4855B9B6FC9014D8D LOCK_DATA_106=534B90C58912806A3B1AEA2508366C357ED6 C38EFDF9B2B25C62D82AEDFBFFAA8D706AE016B61FC3 LOCK_DATA_107=E40C9F80C08A92DD449CE9FF63546B235AFD B6F39066CB5DD947634D8264307A372276EF866174E7 LOCK_DATA_108=9CCD0040767EC922BAA91329F0CE934326FC 788CE846CADC4E3F6CD715CF52A8F9593ABA494B8C5A LOCK_DATA_109=C5542D446C97DE52E72CA45EDF3323F246E2 6E992D1379726E9B0B83D57671AF41F8EE5DEDF46526 LOCK_DATA_110=9A148FC63AF77FEF2D626048DA43CF5C4D6E A4F33A6F83A42DDAD0EBC62B6B60966DDF404B18BE7F LOCK_DATA_111=2EF09EE9409B27CD73CCCE1E49004D67AC43 9042646A5319A5111E09CCC3471912AEED9B15C1E6FB LOCK_DATA_112=91AEC76C91AE2E98FAB430F719DC6B04C659 88B329DA6FA22AC3F5ED817430AE97E6F55BF2FFFFFF LOCK_DATA_113=FF000800000300000002000000AB0FBD96AF 2AC271D26264AFDEAD04002ABD0BFBC58B36B9E46119 LOCK_DATA_114=772B22CB730253DF389A87DF817897D5B1DF 8A73D42CD589A000A6A4137F8463C9E7176A4B9B034D LOCK_DATA_115=4FD8F30E59D3397CC004232DDB2E2842FBBA BC920483FDDF25F883E8268C40B3386D60016304F931 LOCK_DATA_116=D26C592C5E3AB63FBE4C0E7F4CC8F8F2DD73 800E6A22874F3CAC256B1341FF1F29D34045182B1EB6 LOCK_DATA_117=469243D006F71F8C727F37768780F04CBB53 FB1D59BD321394D0DB9B9265A800482C3BD4B6D46B0D LOCK_DATA_118=EE12A18E8861D583CD5D46B2E6070457CED1 E109AAF0BD5F454E723BF948C62C64FE7D5B1528DF63 LOCK_DATA_119=3E3559ED6C2723716E6641F96A954ADDBC3A A9EB98974F1F3E3AA1D7AAC62315FC4D288203067AEC LOCK_DATA_120=C5804B5FF833AFF3D04EDA3BB0900174CF8C 4962F5F758F706652B047FAA896342DE038140FCD099 LOCK_DATA_121=7C7DE0DFE849609584F72B7E803A2E2654B9 F7D0BB340D30EA134249E7F4529B36D34E7DA652D1BD LOCK_DATA_122=B3444A1B976A738900FD4C76268751703DD5 7204DC5B59ABF15855FFE3C71A8F98059822B74B3CFF LOCK_DATA_123=D901C2880F4F6C193A5C986F173080DB539E D2A0980D3105B0DEB169E1721270148FE82E5F2DE5B6 LOCK_DATA_124=E301CC765C40D9306BABEF9CDD19803A2C49 ED1F08385F1614B4B884D6DBC1A4C723C1C8E2A0D258 LOCK_DATA_125=94902B2E7BFC0262E66273291DFB4E02DD0A 566ACBBBC3F83837438BEA2FEC23D58A518F4C5B6A13 LOCK_DATA_126=89A3342A508DCCCD121BAF2F149D8F1C027F D3528CDE48540B6729587D9D3C53FF68F8F88C964480 LOCK_DATA_127=823CE8ECD9882506F2296EDF11FF75505241 19F8D5F1FFF4341EDC33DF75D94D20CB421097A97A40 LOCK_DATA_128=00D271A38C60BD2B5EB76E5768C38F458BAC C5898B29EA696951799BAC5A4CF7A348C0C94D981443 LOCK_DATA_129=E5FEE8079747DEE8EF136C196F313AE521A4 762F16CE62F6619F8735C6B4DE9BAE0EC2C2BEB592C9 LOCK_DATA_130=AE01E66087AABF1F4711C283F52420183291 161B96A27A3C3DEFE3D08F959CEB287D9E5424DEDA8A LOCK_DATA_131=134C24C196A33C833DDD0E84BCE9FFE970D2 8D07F438C74080702DC6B55B4A707B8D9AB8F8594969 LOCK_DATA_132=DB90020B5D268E97F5A5081D9DDD1BC108D5 F392E728889CF125FDA654D7897E8692695E7E3A0BF6 LOCK_DATA_133=6C17EEF55DF2DF5B2A33F1BF17E68BE1C9C1 8E5EB1CFD0A07AB21EF483BAD1136385CFFA8BAF4E2E LOCK_DATA_134=BA05583BEAB8D156FCB920B74F3B75DF555B 38341BCCA96F5C2A37DC6149A6D103888CC1E41556F5 LOCK_DATA_135=117F996DB14AD0057151D687ECC2895CA37C 5BE706DBC6E2B401ECF12A820EBF7A68960051005103 LOCK_DATA_136=DB88980B3B737155FDBF3EB62EAC477B8D77 803263C1141D2BDE6337A2F1450F54578EF375B71AA8 LOCK_DATA_137=753324BCE8F406BE5C86DD31A24D6BDC4E9A 3D5C61E018B15261387FD97A8F69D2657F39E1C9EF13 LOCK_DATA_138=AD45EDE3E44D852EC5A64CA30E2E3C726EB4 C925BAE27D77B8275A8A99241EB1D7DD1959A3858A71 LOCK_DATA_139=7F5500FA2F7D46B3ABBC2476581E829127A2 3D7E293960F9C424D201A38DEAC6491191151C4A9FC5 LOCK_DATA_140=C03076EC85531FA40F75B8DC168C65A2E9BB F21633479EE37ABEEC600091A102992F196314A839D9 LOCK_DATA_141=CB098D671A026C0D52854022C2F9348160FF A6EF445ADB5DAA62D675DFEEBF5375E4058F5E4711AC LOCK_DATA_142=782C09C54B579D328863D67F40E5A954764C FCE57FFBE1AD7987D9E1553425DBEC9773C82F243FFB LOCK_DATA_143=007F8CEE0D097D89DD9A91F46FB52948A7E3 B30CC23468B89C966193D67A4691439CB62A9293D4DE LOCK_DATA_144=055BCD43826BC0E0903FF955B33541ACD5C5 024A6B4C1607DB8E31E9119A92A5B541CC6310877A6A LOCK_DATA_145=6861FD096E8BD44EB7010195487234228F42 00750F9BFB36F5FBABEF6104A819BA9813A3F4FC1DF8 LOCK_DATA_146=C2ADA79DC4FF2C7C83286909E69D4BA04FBB 61D1076153F229B8534DB52513097AE6E607BE0D9CC8 LOCK_DATA_147=908F2AFBA1857A68990A7794084D923CC090 39BE7D0DED6477C0D1AD80A757AAA34E76AE7BFF2124 LOCK_DATA_148=56149AE930397885134D505FB0F1A5C27C3B C764F92B420CC1EA3DF9E65EF38C0242B1C96A634B63 LOCK_DATA_149=770004E9229C8529474DD60583066CD5B8AF 5767633C72E80F5BE662CAF71AF33C09B4AD1983C284 LOCK_DATA_150=C301049DEB72706DB941AA11FFE52C0E5429 9F60E100A6D73BE2FA5CDD57A87A97DDCE7AC297033C LOCK_DATA_151=CB82BC64BF8012C0CBCF833361C0E44BA1F8 A5F9F052036B54BD35374BBA17FD780E754C61EE94B6 LOCK_DATA_152=0804EEDFBDED1890281CCA5252CDEE2233B3 34FD47A39A6F3B1BB66600298807B1C03A2F90DBEE58 LOCK_DATA_153=E8E4A9235A1589B77D1C1F5F1BAC2B1E76ED 4DE6EF1140624F06350F46FF198D6FA1F28E0B0C2739 LOCK_DATA_154=8834D7A4A66424B32756B9A35FF6E81EE159 3CD4F65135FBB98DB5049D1716C37D2B5244342B3306 LOCK_DATA_155=B08D1CCA729AE2824092AF547E9B8197369F 689FCD10A5171331EAAACF279B4853E97C4CE6577DB1 LOCK_DATA_156=AA10F5AA983C7AAB2CDB30DEE2F5204870F2 85C5B3E498AA47CB260FAA8BA2752AAD0C69A97607EB LOCK_DATA_157=25622B6396754246876C5BBB48AAE2A92D48 C3A4291FE671DE153B1D838A73D0A282C4B3D045866C LOCK_DATA_158=AE4F8438676B0E1DB67ADF6870CAAFF322B8 93D9B35B5C9268FD8F37568B9559F76B914FAFEC7131 LOCK_DATA_159=6AB0006E31A9488126EF4DEA3E7B9CDACFC1 A6A6E87C2EE16995E30FC178A12DDC96B172CBAC88E1 LOCK_DATA_160=90FD8C2DA0E27732F2050B7F83700AB4003A 818CEAB47D0EAB3F12C7495157A2B968B56A9774D6BC LOCK_DATA_161=A673451A9B5FAF0930075487E98DBE23FDC6 3687D0528CE0C375539EB27CAB4726DB68E2BEA48D27 LOCK_DATA_162=E58673B47E391F2EB129E9757C67324C08BC 755139CF270B31D4A9211074BDFC200AA58EF58F3D1C LOCK_DATA_163=D65ACB3F737D0CA068608F956DE963766833 5AD90F188E07C1DE56FA3575493C89F9060C89563590 LOCK_DATA_164=170AC61F4B67942D1F2F60F8AE675A624620 7F2A43B3AAA57D727B2806EA7E009218FC70805B0FB0 LOCK_DATA_165=5476775D862E9F3440A48810740000000000 00000000000000000000000000000000000000000000 LOCK_DATA_166=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_167=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_168=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_169=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_170=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_171=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_172=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_173=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_174=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_175=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_176=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_177=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_178=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_179=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_180=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_181=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_182=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_183=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_184=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_185=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_186=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_187=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_188=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_189=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_190=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_191=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_192=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_193=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_194=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_195=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_196=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_197=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_198=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_199=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_200=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_201=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_202=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_203=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_204=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_205=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_206=000000000000030001030004000107000500 0A313233343500000000000006000100000700010000 LOCK_DATA_207=080001000009002800000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_208=0000000000000000 BB_DATA_1=0135000900000004010000000001000201190002 000CFE05010007000000663300000004000C0101 BB_DATA_2=0100BE090000855300000005000C02010100A6FF FFFF08FB01000007000C04020200920400000000 BB_DATA_3=00000008000C050303004F08A00F2A0100000011 000C0E06010000000000FC2600000016000C1301 BB_DATA_4=01000000000010270000 | |
03-13-2010, 22:23 | #4 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | ok bro, try writ this rpl and wait 1 mnt then post here log 4shared.com - online file sharing and storage - download BB5__BACK.rpl |
03-13-2010, 23:03 | #5 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | if ur problem not slove go to 1 full erase on mxkey 2 flash phone 3 writ rpl (my rpl) 4 mxkey>serves>imei&securty>imei rebuild>repair sd 5 go to pm >click sd auth writ pm (wait 2mnt) 6 full factory |
03-13-2010, 23:14 | #6 (permalink) | |
I go to the next step | |
03-14-2010, 01:59 | #7 (permalink) |
Member: 595054 Status: Offline Thanks Meter: 4 | I kill the phone I trying back to the live by usb dead but nothin happen see the log Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm217__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.50 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 472EEA3 RAP SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] RAP EM0 ID: 00000232 RAP EM1 ID: 00000353 RAP PUBLIC ID: 180002180146005266ED62BDFD0B7EC95B0E624E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 191EC665DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 36.950 s |
03-14-2010, 02:30 | #8 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | would you try again .can you back upp all section before you flashing if you have back up restor imei all will be done |
The Following User Says Thank You to lilong_lee For This Useful Post: |
03-15-2010, 08:35 | #11 (permalink) |
Registered User Join Date: Nov 2001 Location: close to your mind Age: 53
Member: 7457 Status: Offline Thanks Meter: 21 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Product: V 07.30 07-05-09 RM-217 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Calculating SUPERDONGLE using security server ... Connecting to server[mxkey.selfip.biz] ...OK, secure login ... SERVER: Imei invalid or empty (12345610654321?)! |
03-15-2010, 08:46 | #12 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
u can write now pm1 and pm309 | |
03-15-2010, 17:02 | #13 (permalink) | |
Then write the rpl with backup2 service>imei & security> imei rebuild> write rpl and select the backup2 or better service>imei & security> imei rebuild> restore imei if your problem is not resolved to do this 1. Full erase on mxkey (flash>advance>get address>erase flash) Note: verify that this selected SAFE ERASE 2. Flash phone (flashing>scan>market and select your model, mx-key automatically load MCU, PPM and CNT>flash) Note: if you don´t have the flash for this phone go to click the button imagen dl and download it 3. Full factory (service> action> Full factory> and reset select) 4. Write rpl (service>imei & security> imei rebuild> write rpl) Backup2 with Fields NPC_DATA, CCC_DATA y HWC_DATA | |
The Following User Says Thank You to suarezfco For This Useful Post: |
03-16-2010, 09:08 | #14 (permalink) |
Member: 7457 Status: Offline Thanks Meter: 21 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 15A00107FF2B7E56659EAC473D0CCA4EA1CAAEE0 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 0041 - 0000 6A21 [AMD ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: 35482601072149 Original Product code: 0531179 Bluetooth ID: 001ADC7B9E2D Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0531179 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
n70 imei 12345654321 | pawansharma5 | Nokia Hardware & Hardware Repair | 9 | 02-13-2009 16:02 |
6300 Erase IMEI itself, after change IMEI!! | KUBAT1 | Infinity-Box | 13 | 12-01-2008 08:10 |
imei 12345654321 | s alali | Nokia Base Band 5 ( BB-5 ) | 4 | 09-09-2006 06:02 |
