03-09-2010, 14:16 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | 6300i simlock data corupted no backup pls solution Phone Type: RM-337 (Nokia 6300i) SW Version: V 05.60 10-12-08 RM-337 (c) Nokia Imei plain: 12345610654321-? Product Code: 0557512 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
03-09-2010, 14:27 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
then make simlock rpl with mx key | |
03-09-2010, 15:06 | #3 (permalink) |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | ............no this one 6300i version 05.60.....it's suppoarted? info:Version Info: MCU SW version: V 05.60 10-12-08 RM-337 (c) Nokia HW version: 1502 RFIC version: 17211721 DSP version: ICPR72_08w47 LCD version: SEIKO PPM version: V 05.60 10-12-08 RM-337 (c) Nokia A BT MCM version: 2222-143C Retu version: 32 Tahvo version: 53 Content Pack version: Content: i_ny V 05.60 10-12-08 RM-337 (c) Nokia Product Info: Production serial number: KIR391484 Product code: 0557512 Module code: 0203491 Basic production code: 0549193 Long production SN: 0 Serial Numbers: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 21 F5 Other Info: Model : Nokia 6300i (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 4.5 KOhm SIMLOCK_DATA corrupted! |
03-09-2010, 15:34 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
if not must be repair with ASK to RPL BB5 calculation the bad news all calculation server BB5 is down br, | |
03-09-2010, 15:45 | #5 (permalink) | |
03-09-2010, 15:52 | #6 (permalink) | |
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | Quote:
you have no solution dont post nokia mobile morethan set the under warrenty! forum users why post in our problem? solve in problem himself and service center!!!!!!! | |
03-09-2010, 15:58 | #7 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | better closed . other user try to help u with give answer and this moment is no solution yet. your are old user, so know about use SEARCHING button right br, |
5030c rm-524 simlock data corupted. what to do? | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-10-2010 09:41 |
5030c simlock data corupted | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-07-2010 06:56 |
6301b Writing SIMLOCK DATA and SIMLOCK DATA KEY... Failed... | dhanrhage_24 | Nokia Base Band 5 ( BB-5 ) | 0 | 05-12-2009 06:43 |
All Other Problems Encountered On Bb5 Unlock Except Sp Data Corupted | huricane | Nokia Base Band 5 ( BB-5 ) | 5 | 06-04-2007 15:11 |
