05-26-2010, 16:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | 6300nokia phone restructed code not repaired with mx key any mxkey masters help me FOR BB5 ITS WORKING LIKE ONCE IN A BLUE MOON 6300nokia phone restructed code not repaired with mx key MY DONGLE SERAL NO:Serial: C0802D64 FW version: 00.20 Counter remain: 92.46% Licenses: 0 = True 1 = True 2 = True - Registered to: ramakrishna RESPECTED MANOLE SIR, WHY I CANNOT REPAIR SD AND SECURITY TEST-FAILED. I AM USING NEW VERSION AND I HAVE 150 DCT4 AND 150 BB5 CREDIT AND MY NET SPEED IS VERY HIGH. BEFORE WHY THIS VERSION PROBLEM Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 35934702379414-4 Product Code: 0572715 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359347023794144 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED AFTER CLICK ON REPAIR SIM LOCK THIS IS MESSAGE DISPLAY mei net: 359347023794144 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. |
The Following User Says Thank You to cellcare prasad For This Useful Post: |
05-26-2010, 17:30 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | Quote: Brother you don't need to worry about phone restriction .. just use this software with jaf or ufs and press unlock your problem will be solved i have used this for lots of sets for phone restricted. best of luck download |
The Following User Says Thank You to ajit bs For This Useful Post: |
05-26-2010, 18:01 | #3 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | THIS IS MESSAGE I AM GWTTING Error. 0x11010363 Error. 0x13010201 Operation time: 00:03. Done with error(s). Thread phone exit. |
05-27-2010, 03:56 | #6 (permalink) | |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | Quote:
I DID THE SAME THING RESULT I AM POSTING \Imei net: 359347023794144 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-217 (c) Nokia. NOTHING MOVING BEFORE I REPAIRED 100 OF MOBILES WHAT WRONG WITH NEW VERSIONS | |
05-27-2010, 03:57 | #7 (permalink) | |
05-27-2010, 04:52 | #10 (permalink) |
No Life Poster Join Date: May 2008 Location: amman
Member: 764174 Status: Offline Thanks Meter: 259 | use init simlocks without (make simlock rpl) if it sl 1 if it sl2 use same button but with (make simlock rpl) after these u solve these (CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF) and all will open but still (security test failed) so now try to write pm(1 & 309) via super sd auth or ppm auth if still failed to repair check (hwc & ccc) then retry with pm again |
07-09-2010, 11:38 | #11 (permalink) | |
Freak Poster Join Date: May 2007 Location: Mumbai, India Age: 41
Member: 513417 Status: Offline Thanks Meter: 87 | use this i tested with 6300+3110c Quote:
use u get error messege forget just prees unlock or ripair sim lock it will done sucsses thx good sharing | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
