08-22-2010, 16:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | 6303 aafter flash dead help Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm443__10.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.67 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 18800115237C7D562DCF6A7A5F518C5C78FBA0EA ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 28.25 MB CMT NOR area [00000000-0001FFFF] erased in 0.250 s CMT NOR area [00040000-0005FFFF] erased in 0.172 s CMT NOR area [00060000-0007FFFF] erased in 0.172 s CMT NOR area [00080000-0015FFFF] erased in 0.297 s CMT NOR area [00160000-0023FFFF] erased in 0.313 s CMT NOR area [01740000-0191FFFF] erased in 0.578 s CMT NOR area [00240000-0173FFFF] erased in 4.969 s CMT NOR area [022E0000-0261FFFF] erased in 0.890 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00080000, Result: 0010 Flashing terminated with error(s) in 38.094 s RX Buffer: C7012D0103CD000010000000F172 please help me set goes to local mode and test mode but now dead |
08-22-2010, 16:48 | #5 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm443__10.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.67 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Unknown ID ! Error getting boot info ! Bootstrap failed! Flashing terminated with error(s) in 52.000 s RX Buffer: Interface: POTATO BOX » BOX FW Version: 01.B4 » BOX Authentication ...OK. POTATO FLASHER INTERFACE ready. Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm443__10.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.67 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 18800115237C7D562DCF6A7A5F518C5C78FBA0EA ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 28.25 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-0005FFFF] CMT NOR area [00060000-0007FFFF] CMT NOR area [00080000-0015FFFF] CMT NOR area [00160000-0023FFFF] CMT NOR area [01740000-0191FFFF] CMT NOR area [00240000-0173FFFF] CMT NOR area [022E0000-0261FFFF] erased in 6.609 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 45.672 s RX Buffer: C7012D0103CD00 with jaf logs |
08-22-2010, 17:08 | #10 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | Using device: POTATO BOX, FW ver: 01.B2 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Unknown ID ! Error getting boot info ! Bootstrap failed! Flashing terminated with error(s) in 52.047 s RX Buffer: |
08-22-2010, 17:08 | #11 (permalink) |
No Life Poster Join Date: Jun 2003 Location: KA , Deutschland Age: 47
Member: 32168 Status: Offline Thanks Meter: 183 | use Phoenix to flash the phone like dead usb...after u click refurbish put cable Without Battery and after that insert battery and pres shortly power.... regards |
08-22-2010, 17:16 | #13 (permalink) |
Freak Poster Join Date: May 2009
Member: 1028136 Status: Offline Thanks Meter: 18 | try reading this brother http://forum.gsmhosting.com/vbb/f550...58/index2.html |
The Following User Says Thank You to e r i k For This Useful Post: |
08-22-2010, 17:29 | #14 (permalink) | |
Junior Member Join Date: Aug 2010
Member: 1374054 Status: Offline Thanks Meter: 14 | Quote:
dear bro i can give u only idea your rx2 conection is missing or broken thats why cant program.. so you colect user manual and try to reconect rx2 pin... good luck bro... | |
The Following User Says Thank You to bigboyb For This Useful Post: |
08-22-2010, 18:14 | #15 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Bro ur jaf box is dead now use another interface or dont use jaf again on MX key bro try to another Fc on usb cable i hope it ll be ok |
The Following User Says Thank You to shh_903 For This Useful Post: |
