Old 12-16-2011, 16:08   #1 (permalink)
rezwan_jack's Avatar
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
The Card is not Responding to resert need help
After Update
MXKEY/MXBOX v3.5 revision 1.6
» Begin transaction ...
Initializing HTI ...
HTI initialized.
Boot version: 00.07
Serial: 0000XXXX
Receive firmware from server ...
SERVER->Served by MXKEY - BLADE Z at upd, agent version 1.1 revision 1.0
Firmware version on server: 00.50
changes:
added: boot mode switch function
improved: serial and flash bus communication routine
added: dct4 product data calc algorithm
added: broadcom sec.repair algorithm
minor bug fixed.
Received buff checksum verified OK.
Waiting for HTI in boot mode ...
Reinitializing HTI ...
Updating HTI firmware, please WAIT ...
HTI firmware update OK.
» End transaction (status: 0, Successfull)
Waiting HTI in application mode ...Done.
Now showing this massage
Thnx in advance
rezwan_jack
Old 12-16-2011, 16:16   #2 (permalink)
Saggio Fenola's Avatar
Member: 1342669
Thanks Meter: 109
The same case also finally ..............
It turns out the problem when installing drivers rockey2000 yes or no .......??
Try reinstalling MXKEY rev 1.6
after the driver install log rockey2000 just click yes and wait served until completion .......
Old 12-16-2011, 16:59   #3 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Thnx for reply but not solve
Still same problem
Old 12-16-2011, 17:04   #4 (permalink)
Registered User
Member: 998932
Sonork: DJ-23
Thanks Meter: 18
is nice good work mx-key team
mr
mobile killer
Old 12-16-2011, 17:07   #5 (permalink)
Registered User
Member: 998932
Sonork: DJ-23
Thanks Meter: 18
MXKEY/MXBOX v3.5 revision 1.6 setup run after update HTI box and your problem solv
Old 12-16-2011, 17:07   #6 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Old 12-16-2011, 17:08   #7 (permalink)
Member: 1158416
Thanks Meter: 182
Try here: http://forum.gsmhosting.com/vbb/f550...ution-1397937/
hope this will help you...
The Following User Says Thank You to analot For This Useful Post:
Old 12-16-2011, 17:13   #8 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
HTI initialized.
Boot version: 00.07
Serial: 0000XXXX
changes:
minor bug fixed.
its already posted
Old 12-16-2011, 17:26   #9 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
Thank u very much Sir. I Solved My problem
Old 12-16-2011, 17:27   #10 (permalink)
Member: 776103
Sonork: 100.1596478
Thanks Meter: 169
After Update
I encountered this problem:
This procedure help me out with that problem:
After that, just Run mobileEx 3.5 (rev1.6) or Restart App:
Old 12-16-2011, 17:54   #11 (permalink)
Member: 1158416
Thanks Meter: 182
no problem buddy, if you encounter the same problem again just unplug and plug HTI box from usb then Restart App..
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.24658 seconds with 10 queries
