05-11-2011, 13:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | 6303 not sucess flash with mxbox help to recitify this problem Version from file: 10.12 MXKEY Serial: [FT SCRxxxx0] - xxxxxxx Using device: HTI BOX, FW ver: 00.07 Driver: FTDIBUS, ver: 2.6.0.0, NTMP ver: 2.6.2.0 Module ver: 1.0.0.16818(08-05-2011), Library ver: 1.0.0.9627(20-04-2011) Reading Important data ... Reading RPL backup ... Reading Phone ID ... SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 52.99 KB Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Sending Overflow Loader(0x2E4 bytes) ... Overflow loader running .. Sending CustomLoader ...OK productData saved. Restarting phone ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 11900103C1978C56548F6B11B66D36647DBA7EBD ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35828103309914 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35828103309914_BA CK.rpl" CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 11900103C1978C56548F6B11B66D36647DBA7EBD ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 TransmissionMode: DDR&TX2 Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, R&D, CCC, HWC] ...OK Erase size: 28.25 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-0005FFFF] CMT NOR area [00060000-0007FFFF] CMT NOR area [00080000-0015FFFF] CMT NOR area [00160000-0023FFFF] CMT NOR area [01740000-0191FFFF] CMT NOR area [00240000-0173FFFF] CMT NOR area [022E0000-0261FFFF] erased in 2 min 32.016 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Error while programming [00] at 0x00A28400, Result: 0000 |
05-12-2011, 03:28 | #4 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | my friends i have ufs, cyclone, atf, jaf, mxbox. it was ok another box why error in this newly launched mxbox i need solution |
The Following User Says Thank You to cellcare prasad For This Useful Post: |
05-12-2011, 12:05 | #5 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | No more reply from supporter and friends and they are adviseing use another box its not wright way |
05-13-2011, 15:44 | #8 (permalink) |
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | No more reply from supporter and friends and they are adviseing use another box its not wright way, what is use to buy to mx box. i am afraid use mx box |
05-13-2011, 16:00 | #9 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | Quote:
i had also this problem.... but i solve it... 1st i change cable of mxbox...(mostly cable fault...use original) if not done then change ur xp...(now i m change my xp to win7) my mxbox work perfect | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
