Old 10-06-2012, 18:07   #1 (permalink)
Member: 382783
Thanks Meter: 118
6303c error after flash
i flashed nokia 6303c but after a few minutes restart
this log:
Phone type: RM-443 (Nokia 6303 classic)
SW version: V 10.10 18-11-09 RM-443 (c) Nokia
Imei plain: 35603603247298-1
Product code: 0568866
Battery voltage: 4987 mV, current: 52 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356036032472981
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
Old 10-06-2012, 19:28   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
It's Superdongle Key Invalid,
Click Super SD Auth & Repair SD will solve it.
BR,
ZUBER
Old 10-06-2012, 21:39   #3 (permalink)
Member: 382783
Thanks Meter: 118
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
Thanks Bro it ok ok But gaves an other error
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Counter: 0/3, 0/10
when i powered on the phone gaves Contact service
Old 10-06-2012, 23:15   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-443.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
Old 10-07-2012, 13:36   #5 (permalink)
Member: 382783
Thanks Meter: 118
Bro.
BR,
ZUBER
Thaaaaaaaaaaaaaaaaaaaaanks veeeeeeeeeeeeeeeery much Bro ZUBER it's ok ok ok ok ok okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
Battery voltage: 4988 mV, current: 54 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
but what about this message:
Old 10-07-2012, 14:45   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Ignore this Message,
You will see this in Logs when Phone is SL3,
To make User Precaution to avoid killing Phone.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Page generated in 0.26126 seconds with 7 queries
