03-16-2010, 18:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | 6303c USB flashing problem with error |
03-16-2010, 18:46 | #3 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | My porblem was been in pressed(hold time) time to power button-must be longly pressed power button. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm443__09.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.61 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2142F10D RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 2970010D01AC8A56D9FB4C6950A2BDD5D9FFB38E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x68680 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x76C80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 30.360 s But with this problem... |
03-16-2010, 18:48 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | uninstall Nokia Connectivity cable driver from start -> setting -> control panel -> add and remove program install "Nokia_Connectivity_Cable_Driver.msi" from Code: C:\mobileEx\3.3\data\drivers\nokia afterward retry your JOB br, |
03-16-2010, 19:13 | #5 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | After solution... Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm443__09.10.mcusw as MCU [BB5,BB5 ALGORITHM] size: 24.61 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2142F10D RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 2970010D01AC8A56D9FB4C6950A2BDD5D9FFB38E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x68680 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x76C80 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 26.704 s Can't help, need next solution? |
03-16-2010, 20:20 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
just change usb port and also use full charged battery many time tested this model in this tool am sure ur problem will solve 100% | |
NOKIA 3500c DEAD USB FLASHING PROBLEM WITH MX-KEY:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 06-14-2009 12:43 |
3120c USB Flashing problem With UB | Faridava | Universalbox | 1 | 09-15-2008 18:29 |
flashing problem with USB Cable | SmilingFace | MT-BOX | 1 | 08-13-2007 10:51 |
