01-08-2010, 09:56 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Indonesia
Member: 368629 Status: Offline Thanks Meter: 87 | 6500 Blink After Write Backup RPL I Have a 6500 slide phone that come in with network problem.. so i try SX4 and write modified PM... But the problem is in this few days the server is down... So i tried to backup the RPL (before that i scan the superdongle key test passed..) the i erase the NPC and write PM then i write back the Backup RPL the Phone become Blinking (Can go local mode and if i switches on with battery it's showing Nokia with Light coming up and shut off again..) So i search in this forum, and got solutions said need to do full erase, then i do so.. after erase i flash normal package MCU, PPM and CNT the phone goes to local mode again.. Then i try to write back the backup RPL again, the become become blinking again.. so i do erase again and reflash it I try to Edit the RPL content with Note pad i remove this line: LOCK_DATA_1=bla3 the save as another RPL file and write to phone the phone working now.. but the probem is the superdongle key already corrupted then i got watchdog problem ANy solutions for this model? |
01-08-2010, 18:10 | #3 (permalink) |
Freak Poster Join Date: Jun 2008 Location: ARROUND THE WORLD...."
Member: 796141 Status: Offline Thanks Meter: 25 | I have same problem with N73 (rm-133) after restore Imei Backup the Phone become Blinking (Can't go local mode and if i switches on with battery it's showing Nokia with Light coming up and shut off again) i do bb5 downgread but problem can't be solved br |
01-09-2010, 09:08 | #5 (permalink) | |
Member: 796141 Status: Offline Thanks Meter: 25 | Quote:
Imei: 35185101960268 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 4A38F719931603CF084B981C6718BB2FC016272B ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 1DF00012C19F015462EF865BB6BE2F3F7F507449 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC NPC verified Ok. Updating CMT NPC ...OK Certificate programmed successfully ! Phone not responding ! | |
01-10-2010, 15:46 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | FLASH with original Product Code. try check RPL backup,that have CCC and HWC ? gbluez answer should be fixing that but some reason can be make other result here . br, |
01-10-2010, 17:52 | #10 (permalink) |
Member: 796141 Status: Offline Thanks Meter: 25 | I do reset NPC but problem same just solved my problem with JAF. 1. erase with file erase 2. write rpl 3. flash 4. phone come to be normal again To MobileEx team. plz remove this bug especially once the flash problems, and write RPL backup. br bireun |
01-10-2010, 21:56 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
The Following User Says Thank You to gbluez For This Useful Post: |
N76 blinking after write RPL beckup | sajidashraf | Universalbox | 2 | 02-08-2010 16:39 |
3110c still 123456 after write backup rpl????? [SOLVED] | gioguanez | Cyclonebox | 11 | 01-20-2010 13:28 |
Need Help... N73(rm-133) come to Blink After write RPL backup | bireun | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-10-2010 06:33 |
6300 blinking after pm backup write | ras | MT-BOX | 6 | 11-04-2007 22:54 |
