Old 06-30-2010, 15:27   #1 (permalink)
Member: 608370
Thanks Meter: 89
6500 silder stop on nokia
i have nokia 6500 to flash. it stops on nokia mono then turn off.
i have flashed it with mx key and hwk but failed to solve this problem:
Great masters are requested to help.
LOg below:
Version from phone: 10.00
Version from file: 10.00
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm240__10.00.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 20.39 MB
Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 12A00214D0F50154178FAF584CA61F924BE1E93C
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
TransmissionMode: DDR&TX2
Erase size: 21.87 MB
CMT NOR area [00000000-0001FFFF] erased in 0.531 s
CMT NOR area [00040000-000BFFFF] erased in 1.687 s
CMT NOR area [000C0000-0013FFFF] erased in 0.328 s
CMT NOR area [01480000-015FFFFF] erased in 4.735 s
CMT NOR area [00140000-0147FFFF] erased in 56.312 s
Flash programming ...
CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) written.
Programming completed in 12 min 51.187 s
Processing file: rm240__10.00.ppm_b as PPM
[BB5,BB5 ALGORITHM] size: 5.64 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 6.75 MB
CMT NOR area [01600000-01CBFFFF] erased in 17.765 s
Programming completed in 3 min 42.765 s
Processing file: rm240__10.00_ISM_006.image_c_ch_brown as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 11.51 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34.87 MB
CMT NOR area [01FC0000-03F9FFFF] erased in 40.406 s
CMT NOR area [01CC0000-01FBFFFF] erased in 9.187 s
Programming completed in 6 min 54.031 s
Flashing completed in 27 min 11.703 s
Phone not responding !
Total time to process is 27 min 36.328 s
The Following User Says Thank You to prime_master786 For This Useful Post:
Old 06-30-2010, 15:31   #2 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 686
flash in dead usb method...............
Old 06-30-2010, 17:33   #3 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
LOg below:
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 6.75 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Its because the phone cannot enter different mode, like local mode etc, To fix this first backup at least The NPC cert( the IMEI). This is sl2 phone, so no need to worry about simlock and all coz MX can unlock it successfully. Then do complete erase and then flash it again with latest firmware and then restore IMEI. If it can enter local mode, you can repair SD and simlock now. If still cannot enetr local mode, do a BB5 software downgrade fix which is in Service->Quick Fix.
curvenger
Old 06-30-2010, 19:51   #4 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,122
Brother Flash ur 6500 with Latest Version of rm240__10.30
I already done 3 phones with this Version in same problem
best of luck
Old 06-30-2010, 20:48   #5 (permalink)
dil7689's Avatar
Member: 1080396
Thanks Meter: 1,661
good work bro
and thanks
The Following User Says Thank You to dil7689 For This Useful Post:
Old 07-01-2010, 05:58   #6 (permalink)
Member: 608370
Thanks Meter: 89
best of luck
Brother,
can you paste here exact file name here????????
Thanks,
Old 07-01-2010, 06:51   #7 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,426
brother try this version rm240__10.30
same error faced u must check hardware(remove handfree driver)
Old 07-01-2010, 11:13   #8 (permalink)
Member: 608370
Thanks Meter: 89
best of luck
still same problem with 10.30
Old 07-02-2010, 16:13   #9 (permalink)
Member: 608370
Thanks Meter: 89
curvenger
failed to get back up of rpl
what can i do more?
Old 07-02-2010, 17:00   #10 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,390
follow steps -
- make imei backup no worry if rpl.pm is not backuped
-load unirap.bin in mcu ppm flash set
-now flash set with desired version of firmware no worry if version is old
use MT box with 10 pin cable for best result
go in extra tick first 3 option and last 4 options
do post results -
br,
Old 07-02-2010, 20:26   #11 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Originally Posted by ~AKSingh~ View Post
follow steps -
do post results -
br,
This is Mxkey section, not MT. Sorry Bro.
Old 07-02-2010, 20:32   #12 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
what can i do more?
You cannot backup full rpl if the phone cannot enter local mode. To backup IMEI, Go to Service->Imei & Security-> IMEI Rebuild, in the section, select NPC only(RAP NPC, not APE NPC) instead of All Section. That way, you backup the IMEI even if the phone cannot enter local mode. After backup erase and follow the instruction I've written above.
curvenger
Old 07-03-2010, 07:02   #13 (permalink)
Member: 351924
what can i do more?
did u try my hardware solutions?
why ru reject my solution?
Old 07-03-2010, 07:21   #14 (permalink)
Member: 608370
Thanks Meter: 89
i dont have permission to open by the coustomer
Old 07-03-2010, 07:48   #15 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,532
follow AKsingh instruction i hope you will success
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.46192 seconds with 9 queries
