Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-13-2010, 09:28   #1 (permalink)
Member: 735092
6500 usb error
please help i have problem flashing 6500slide have error check the logs now the mobile only nokia and then off
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Processing file: rm240__03.80.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 19.84 MB
Supported RAP Ids: 0103192101003000, 010C192101003000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 20E56026
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
RAP EM0 ID: 00000295
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 10A00114ADD48A56389F252690560465EB036997
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x46F40 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x55300 bytes
[ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 3858B713
[ADL] Verifying communication to device OK.
Total erase size: 21.12 MB
CMT NOR area [00000000-0001FFFF] erased in 0.391 s
CMT NOR area [00040000-000BFFFF] erased in 1.656 s
CMT NOR area [000C0000-0013FFFF] erased in 0.094 s
CMT NOR area [013C0000-0153FFFF] erased in 2.969 s
CMT NOR area [00140000-013BFFFF] erased in 1 min 0.516 s
Flash programming ...
CMT PAPUBKEYS: A69838E8C5F20150E64E2E6E06DE6E50B26B593F (RAP Certificate 84 v1) written.
Programming completed in 2 min 15.047 s
Processing file: rm240__03.80.ppm_f as PPM
[BB5,BB5 ALGORITHM] size: 4.96 MB
Total erase size: 6.50 MB
CMT NOR area [01540000-01BBFFFF] erased in 20.844 s
Programming completed in 34.266 s
Processing file: rm240__03.80_ism_007.image_f as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
Total erase size: 35.87 MB
CMT NOR area [01EC0000-03F9FFFF] erased in 53.750 s
CMT NOR area [01BC0000-01EBFFFF] erased in 9.016 s
Programming completed in 1 min 10.094 s
[ADL] Phone flashing completed, but failed to verify communication to
product!
[ADL] Retrying in finalize phase...
Old 03-13-2010, 10:51   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
uninstall nokia connectivity cable driver
and install from MXKEY directory
restart your PC , and retry your JOB
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-13-2010, 10:56   #3 (permalink)
Riz000's Avatar
Member: 777415
Sonork: 1589702
check fbus cable if set not local or test mode come then flash again with fbus cable if still then backup npc data and erase phone with erase file
and flash with any version and after flash write npc data if still no test or local mod come then open set pcb clean bord and heat all bord with light heat and then conect with box local or test mode come and after local or test mod come u need to repaier simlock with simlock rpl and sd repair and last replace rpl CCC_DATA and HWC_DATA with other 6500 model or mx key colne rpl collection then write pm 1&309 With super sd auth then post result.
TesTed
The Following User Says Thank You to Riz000 For This Useful Post:
Old 03-13-2010, 12:30   #4 (permalink)
Member: 735092
i try to flash in ub and hwk the flash finish but the but the phone still only nokia..i try it with version 10.00 and 10.30 but still same like this the pone is in warranty period so i cannot make hardware the reading in the fbus is only this i cant read the imei and simlock
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F
Original Imei: 35690503025864
Original Product code: 0549740
Bluetooth ID: 00266943CFCA
Phone not responding !
Old 03-13-2010, 13:10   #5 (permalink)
Riz000's Avatar
Member: 777415
Sonork: 1589702
its 100% hardware just clean bord and heat bord with light heat ur problem solve tested
6500s unlocking error with usb umerfarooq Cyclonebox 1 03-10-2010 11:38
6500 cmd error flash.Error finding cmd loader... parand Nokia Hardware & Hardware-Repair Area 0 12-24-2008 17:35
nokia 6500 usb flashing error saurabh_bhola Nokia Base Band 5 ( BB-5 ) 10 09-21-2008 09:12
Mt-box 1.52 usb flash 6500s rm278 error xuangewen MT-BOX 0 09-10-2008 08:55
Page generated in 2.57329 seconds with 11 queries
