Old 06-08-2011, 08:01   #1 (permalink)
Member: 1480973
Thanks Meter: 25
mxkey team help me 1661-2b
MXKEY Serial: [FT SCR2000 0] - xxxxxxxx
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.6.0.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00E053CBA3BDA66
ASIC type: 11
UEM Imei: 01188500170078
Flash Imei: 01188500170078
MasterCode: 6172446210
RPL saved to "C:\mobileEx\3.5\data\backup\01188500170078_BACK.r pl"
Phone Type: RH-121
SW Version: V 03.00 02-09-09 RH-121 (c) Nokia
Imei plain: 01188500170078-1
Product Code: 0576976
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: UB
Language Pack:
- not available.
Imei net: 01188500170078
Version: SIMLOCK SERVER
Provider: T-Mobile USA , Country: United States
Counter: 0/3, 0/10
CONFIG_DATA: 3102000000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=CLOSED(MCCMNC), DATA=310160 [United States-T-Mobile USA ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=310200 [United States-T-Mobile USA ]
BLOCK3: 1=CLOSED(MCCMNC), DATA=310210 [United States-T-Mobile USA ]
BLOCK4: 1=CLOSED(MCCMNC), DATA=310220 [United States-T-Mobile USA ]
BLOCK5: 1=CLOSED(MCCMNC), DATA=310230 [United States-T-Mobile USA ]
BLOCK6: 1=CLOSED(MCCMNC), DATA=310240 [United States-T-Mobile USA ]
BLOCK7: 1=CLOSED(MCCMNC), DATA=310250 [United States-T-Mobile USA ]
BLOCK8: 1=CLOSED(MCCMNC), DATA=310260 [United States-T-Mobile USA ]
BLOCK9: 1=CLOSED(MCCMNC), DATA=310270 [United States-T-Mobile USA ]
BLOCK10: 1=CLOSED(MCCMNC), DATA=310310 [United States-T-Mobile USA ]
BLOCK11: 1=CLOSED(MCCMNC), DATA=310580 [United States-Inland Cellular Telephone Company ]
BLOCK12: 1=CLOSED(MCCMNC), DATA=310660 [United States-T-Mobile USA ]
BLOCK13: 1=CLOSED(MCCMNC), DATA=310800 [United States-T-Mobile USA ]
BLOCK14: 1=CLOSED(MCCMNC), DATA=310490 [United States-T-Mobile USA ]
The Following User Says Thank You to mdnoyan For This Useful Post:
Old 06-08-2011, 08:05   #2 (permalink)
GSM_HABIB's Avatar
Member: 1199125
Sonork: 100.1609676
Thanks Meter: 297
it not possibale check imie o11
Old 06-08-2011, 08:05   #3 (permalink)
Cheater -Don't Deal with him-
Member: 1390802
Thanks Meter: 1,101
this is x gold set.not possible mx key,try to cyclone or ub...
Old 06-08-2011, 08:09   #4 (permalink)
Member: 1480973
Thanks Meter: 25
sim not valid ................................
Old 06-08-2011, 09:06   #5 (permalink)
Member: 1480973
Thanks Meter: 25
sim not valid
ASIC type: 11
Phone Type: RH-121
Ppm Id: UB
Language Pack:
- not available.
Counter: 0/3, 0/10
I am flash 1661 RM-122
Remove the filter and make jumper
Write the pm
but same problem
MXKEY Serial: [FT SCR2000 0] - C08437A9
ASIC type: 11
Phone Type: RH-122
SW Version: V 05.01 23-09-09 RH-122 (c) Nokia
Product Code: 0573231
Ppm Id: MS
Language Pack:
- not available.
Counter: 0/3, 0/10
plz help
Old 06-08-2011, 09:12   #6 (permalink)
GSM_HABIB's Avatar
Member: 1199125
Sonork: 100.1609676
Thanks Meter: 297
it is not possibale to bangladesh if u ok this mobile then mobile show no network found so don't lost ur time
The Following User Says Thank You to GSM_HABIB For This Useful Post:
Old 06-08-2011, 09:15   #7 (permalink)
sajid_rind's Avatar
Member: 1333635
Thanks Meter: 67
br 1st full erase than flash and check .....
Old 06-08-2011, 09:17   #8 (permalink)
shohag gsm2's Avatar
Member: 1414328
Sonork: 100.1619742
Thanks Meter: 148
imie o11xxxxxxxxx..............it is not possibale to bangladesh.
The Following User Says Thank You to shohag gsm2 For This Useful Post:
Old 06-08-2011, 09:29   #9 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 167
in mxkey go to imei security then simlock
nw tick on init simlock & click on update splock
Old 06-08-2011, 09:33   #10 (permalink)
Member: 1480973
Thanks Meter: 25
not unlock Than mxkey
Uploaded with ImageShack.us
Old 06-08-2011, 09:38   #11 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
try with lower version with mx key
Old 06-08-2011, 12:35   #12 (permalink)
Member: 986942
try flash the phone sir with the rh-122 firmware then write pm and unlock and do hard filter convertion..
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.23302 seconds with 9 queries
