03-26-2011, 09:38 | #4 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | I DONE IT Version Info: MCU SW version: V 5.52 19-09-03 NHL-4 (c) Nokia. HW version: 0660 PCI version: 0 UEM version: 8 UPP version: 4384 RFIC version: 0203 DSP version: V4.61 LCD version: SED15G10 PPM version: V 5.52 19-09-03 NHL-4 (c) Nokia. C Bluetooth ID: 00 A5 A5 00 5B 02 DVB-H receiver Bootloader version: [ Product Info: Production serial number: CMC090246 Product code: 0509510 Module code: 0 Basic production code: 0507780 Flash code: 0 Order number: 0 Long production SN: 0 ATO: 0 Serial Numbers: IMEI warranty: 351**************** IMEI plain: 351*************** IMEI spare to net: 3A 15 53 40 10 06 17 IMEI SV to net: 33 15 53 40 10 06 17 50 F3 PDC: 4E 54 54 4A 50 12 34 56 Other Info: Model: Nokia 7210 (Fashion Phone) CS type: GSM900/GSM1800/GSM1900 Project Name: Vanessa BSI: 0.0 KOhm Imei net: 351*************** Version: SIMLOCKLIB VERSION 2.26 Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
03-26-2011, 09:42 | #5 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | to all, with the same case, how to repair all dct4 corrupted imei: Rebuild Imei: DCT4 > Service > Imei & Security > Online Logger. - press login, DCT4 IMEI proceed with simlock - untick direct unlock > init simlock BR |
The Following User Says Thank You to gbluez For This Useful Post: |
03-27-2011, 13:43 | #9 (permalink) | |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CBE439:2984DA60 ASIC type: 2 UEM Imei: 35135040160710 Flash Imei: 35135040160710 MasterCode: 7233765446 RPL saved to "C:\mobileEx\3.4\data\backup\35135040160710_BACK.r pl" Phone Type: NHL-4 (Nokia 7210) SW Version: V 5.65 19-Nov-04 NHL-4 (c) Nokia. Imei plain: 35135040160710-0 Imei OTP: 35135040160710 Product Code: 0509510 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: Q Language Pack: English,Chinese S,Chinese T (Hong Kong) Imei net: 35135040160710 Version: SIMLOCKLIB VERSION 2.26 - fixed version for more TDS-6 boxes Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN mobile is on but after 10 sec. off when i write imei by mistake 351350401607100 i press *#92702689# imei is 351350401697101 original print imei 351350401697101 how to change original imei | |
03-27-2011, 14:08 | #11 (permalink) | |
LCD version: SED15G10 PPM version: V 5.65 19-Nov-04 NHL-4 (c) Nokia. D Bluetooth ID: 00 A5 A5 00 5B 02 DVB-H receiver Bootloader version: [ Product Info: Production serial number: CMC090246 Product code: 0509510 Module code: 0 Basic production code: 0507780 Flash code: 0 Order number: 0 Long production SN: 0 ATO: 0 Serial Numbers: IMEI warranty: 351350/40/169710/1 IMEI plain: 351350401607100 IMEI spare to net: 3A 15 53 40 10 06 17 IMEI SV to net: 33 15 53 40 10 06 17 50 F5 PDC: 4E 54 54 4A 50 12 34 56 Other Info: Model: Nokia 7210 (Fashion Phone) CS type: GSM900/GSM1800/GSM1900 Project Name: Vanessa BSI: 0.0 KOhm Imei net: 35135040160710 Version: SIMLOCKLIB VERSION 2.26 - fixed version for more TDS-6 boxes Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN | |
03-27-2011, 14:31 | #13 (permalink) | |
SW version: ID Test name Startup Result 46 UEM_CBUS_IF Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 1 AUX_DA_LOOP Y PASSED(00) 3 EAR_DATA_LOOP Y PASSED(00) 17 TX_IDP_LOOP Y PASSED(00) 18 TX_IQ_DP_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 6 IR_LOOP Y !NO SIGNAL(06) 8 MBUS_RX_TX_LOOP Y PASSED(00) 20 BACKUP_BATT Y !FAILED(01) 42 RADIO N !NOT EXECUTED(03) 39 WARRANTY N !NOT EXECUTED(03) 51 PA_TEMP Y PASSED(00) 33 SIM_LOCK Y PASSED(00) 10 PPM_VALIDITY N PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 41 FLASH_CHECKSUM N PASSED(00) 54 EXT_RAM_DATA_BUS N !NOT EXECUTED(03) 55 EXT_RAM_ADDR_BUS N !NOT EXECUTED(03) 30 RF_CHIP_ID N !NOT EXECUTED(03) 45 IR_IF N !NOT EXECUTED(03) | |
03-27-2011, 14:38 | #14 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | not this test, WD Timer, on various tab. forget it.. reset data1, full erase, untick safe erase. reflash. rebuild imei, how is the way, described above. write pm, init simlock, all described above. if phone still turned off after seconds: uem damaged, also described above. BR |
03-27-2011, 14:53 | #15 (permalink) | |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
