Old 06-25-2012, 05:08   #1 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
6630 SECURITY_TEST failed help me plzzz
i am pm but same problem help me any body plzzzzz
Phone type: RM-1 (Nokia 6630)
SW version: V 3.0436v32 04-01-05 RM-1 (c) NOKIA.
ApeCoreSw: V 3.45.113
Imei plain: 35567700934639-2
Product code: 0518165
Battery voltage: 4970 mV, current: 77 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355677009346392
Version: SIMLOCK SERVER VERSION 53
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 06-25-2012, 05:14   #2 (permalink)
Asia_Phone's Avatar
Member: 1300241
Sonork: 100.1626973
Thanks Meter: 356
Try this solution:
  • Repair SD
  • Super SD Auth
  • PMM Auth
  • Write pm then Full factory
The Following User Says Thank You to Asia_Phone For This Useful Post:
Old 06-25-2012, 05:20   #3 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
hello bro. u repair ppm autho,ya super sd ya repair sd then load perfect pm file without 308 then write after reset all,ur problem will be solve. u see write pm file time 1 or 309,writting is ok then ur set is ok
The Following User Says Thank You to mobilehelper For This Useful Post:
Old 06-25-2012, 05:36   #4 (permalink)
jasper-j's Avatar
Member: 1015414
Thanks Meter: 155
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
flash it in higher version everything well be ok
br,
gsmbicol
The Following User Says Thank You to jasper-j For This Useful Post:
Old 06-25-2012, 05:39   #5 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
thanks bro for rply bro write pm
Section: 43
Warning: failed to write 43 - 5 (4 bytes)
Section:
Section: 1
- Key: 0, size 116 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 88 bytes written.
- Key: 4, size 112 bytes written.
- Key: 5, size 4 bytes written.
- Key: 6, size 88 bytes written.
- Key: 8, size 112 bytes written.
- Key: 13, size 88 bytes written.
- Key: 15, size 4 bytes written.
- Key: 16, size 88 bytes written.
- Key: 18, size 88 bytes written.
- Key: 20, size 86 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 16 bytes written.
- Key: 29, size 6 bytes written.
Section: 2
- Key: 0, size 340 bytes written.
Section: 4
- Key: 0, size 1 byte written.
- Key: 1, size 16 bytes written.
- Key: 2, size 44 bytes written.
- Key: 3, size 12 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 8 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 byte written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 byte written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 byte written.
- Key: 13, size 1 byte written.
- Key: 14, size 1 byte written.
- Key: 15, size 1 byte written.
- Key: 16, size 1 byte written.
- Key: 17, size 1 byte written.
- Key: 18, size 1 byte written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 byte written.
- Key: 22, size 1 byte written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 1 byte written.
- Key: 30, size 1 byte written.
- Key: 31, size 1 byte written.
- Key: 32, size 1 byte written.
- Key: 33, size 1 byte written.
- Key: 34, size 1 byte written.
- Key: 35, size 1 byte written.
- Key: 36, size 1 byte written.
- Key: 37, size 1 byte written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 byte written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 byte written.
- Key: 56, size 1 byte written.
- Key: 57, size 1 byte written.
- Key: 58, size 1 byte written.
- Key: 59, size 1 byte written.
- Key: 60, size 1 byte written.
- Key: 61, size 1 byte written.
- Key: 62, size 1 byte written.
- Key: 63, size 1 byte written.
- Key: 64, size 1 byte written.
- Key: 65, size 1 byte written.
- Key: 66, size 2 bytes written.
- Key: 67, size 2 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 4 bytes written.
- Key: 109, size 4 bytes written.
- Key: 110, size 1 byte written.
- Key: 111, size 4 bytes written.
- Key: 112, size 4 bytes written.
- Key: 113, size 4 bytes written.
- Key: 114, size 4 bytes written.
- Key: 115, size 16 bytes written.
- Key: 116, size 4 bytes written.
- Key: 117, size 2 bytes written.
- Key: 118, size 2 bytes written.
- Key: 119, size 857 bytes written.
Section: 17
Section: 25
- Key: 0, size 64 bytes written.
Section: 26
- Key: 0, size 16 bytes written.
- Key: 1, size 32 bytes written.
- Key: 2, size 68 bytes written.
- Key: 3, size 6 bytes written.
Section: 27
- Key: 0, size 15 bytes written.
Section: 29
- Key: 0, size 6 bytes written.
Section: 35
- Key: 0, size 10 bytes written.
Section: 43
Section: 44
Section: 50
- Key: 0, size 2 bytes written.
Section: 54
Section: 88
- Key: 0, size 36 bytes written.
Section: 94
- Key: 0, size 40 bytes written.
Section: 95
- Key: 1, size 1 byte written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 117
- Key: 1, size 3 bytes written.
- Key: 2, size 6 bytes written.
- Key: 3, size 1 byte written.
- Key: 4, size 9 bytes written.
- Key: 5, size 10 bytes written.
- Key: 6, size 8 bytes written.
- Key: 13, size 3 bytes written.
- Key: 14, size 3 bytes written.
Section: 118
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 7, size 1 byte written.
Section: 217
- Key: 0, size 32 bytes written.
- 239 skipped
Section: 248
- Key: 0, size 120 bytes written.
Section: 307
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 11 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Completed in 17.000 s
Old 06-25-2012, 05:54   #6 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
thanksss bro flash latest v phone ok
SW version: V 04wk47_m_v14.2 27-09-06 RM-1 (c) Nokia.
ApeCoreSw: V 6.03.40
Battery voltage: 4605 mV, current: 72 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Phone version(6.03.40) outdated, selected version is:
Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Old 06-25-2012, 05:59   #7 (permalink)
jasper-j's Avatar
Member: 1015414
Thanks Meter: 155
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
you know how too push THANKS BUTTON SIR..heheh
you can add me in your ym you can ask me a question
here,
[email protected]
br,gsmbicol
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.25065 seconds with 9 queries
