Old 10-08-2012, 13:50   #1 (permalink)
Member: 421487
Thanks Meter: 49
6682 unlock failed pl chck why
Imei net: 356658000150602
Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task
Provider: Cingular Wireless , Country: United States
Counter: 0/3, 0/10
CONFIG_DATA: 3101700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=310150 [United States-Cingular Wireless ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=310150 [United States-Cingular Wireless ]
BLOCK3: 1=CLOSED(MCCMNC), DATA=310170 [United States-Cingular Wireless ]
BLOCK4: 1=CLOSED(MCCMNC), DATA=310170 [United States-Cingular Wireless ]
BLOCK5: 1=CLOSED(MCCMNC), DATA=310410 [United States-Cingular Wireless ]
BLOCK6: 1=CLOSED(MCCMNC), DATA=310410 [United States-Cingular Wireless ]
BLOCK7: 1=CLOSED(MCCMNC), DATA=311180 [United States-Cingular Wireless, Licensee Pacific Telesis Mobile Services, LLC ]
BLOCK8: 1=CLOSED(MCCMNC), DATA=311180 [United States-Cingular Wireless, Licensee Pacific Telesis Mobile Services, LLC ]
Backup already exist.
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0802E71
Using device: HTI, FW ver: 00.50, SN: 00012946
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Phone type: RM-58 (Nokia 6682)
SW version: V 04wk47_m_v2 16-06-05 RM-58 (c) Nokia.
ApeCoreSw:
V 3.01.1
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: 54B1172C70F10B353A9BD2AC1FA9497267F5B328
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006
000C192101002100 [RAP3G ver: PA 2.0]
EM0 ID: 00000232
EM1 ID: 00000341
PUBLIC ID: 130001139E984F57BCF9B6CF3570963FC7CA6E01
ASIC MODE ID: 00
ROOT KEY HASH:
E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FAC901AEE
SecondaryBoot: RAP3Gv30_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B80
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
ERROR: Configuration request failed !
Unknown ID !
Error getting boot info !
ERROR: bootstrap failed!
Old 10-09-2012, 13:49   #2 (permalink)
Member: 421487
Thanks Meter: 49
Imei plain: 35665800015060-2
Product code: 0520075
Battery voltage: 4669 mV, current: 75 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Security code: 12345
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-09-2012, 14:57   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Already unlock dear blocks is open.
your problem here.Go to Service Tab > Click Load pm 1-309 field with pmm OR SD auth do write job don & Buscheck you will see the positive Result.
BR.
Arsalan gsm2000.
Old 10-09-2012, 15:15   #4 (permalink)
Member: 421487
Thanks Meter: 49
Battery voltage: 4624 mV, current: 101 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Retrying ...
Old 10-09-2012, 15:31   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-58.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-09-2012, 16:05   #6 (permalink)
Crazy Poster
Member: 447829
Sonork: 100:1622585
Thanks Meter: 11
Originally Posted by .::zuber::. View Post
bro.
Go to service tab > click load from file > select address: C:\mobileex\3.5\modules\{3ebaf427-9f55-419f-8a75-385dfc651169}\def\rfbb & select rm-58.pm file,
now click repair sd & click no to pop up window, click write & buscheck you will see the positive result.
Br,
zuber
you are a good supporter.
Receive my congratulations for joining mxkey helpdesk to help mxkey user.
Thnx.
The Following User Says Thank You to shadd For This Useful Post:
Old 10-10-2012, 13:55   #7 (permalink)
Member: 421487
Thanks Meter: 49
sir pl check its not authried pl check Phone type: RM-58 (Nokia 6682)
ApeCoreSw: V 3.01.1
Battery voltage: 4771 mV, current: 58 mA
Language Pack:
- not available.
Connecting to server[main.mxkey.biz] ...SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Retrying ...
Authenticating using [MX] security server ...
Old 10-10-2012, 14:06   #8 (permalink)
Member: 421487
Thanks Meter: 49
http://s11.postimage.org/9briqc2yb/Untitled_2.png
Old 10-11-2012, 12:36   #9 (permalink)
Member: 421487
Thanks Meter: 49
dear where is supporter ?????????????????????????????????????????????????? ????????
Old 10-11-2012, 12:42   #10 (permalink)
Member: 1325931
Sonork: 100.1606274
Thanks Meter: 38
click repair sd
then click no
now you can right pm 1 to 309...
goodluck....
Old 10-11-2012, 18:18   #11 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Am here,
No need of so many ????????? Question marks.
But what about my solution, you didn't follow my procedure & trying online with SX4 Server etc.
Load File & Write from the same of my above post must work for you.
BR,
ZUBER
Old 10-12-2012, 16:23   #12 (permalink)
Member: 421487
Thanks Meter: 49
dear am not new i use mx key last many year i fallows instruction and load file u given path when i press sd repair [ phone start up failed] ERROR: Configuration request failed !
Unknown ID !
where is no i cannot understand above post [Now click Repair SD & click no]
Old 10-12-2012, 16:53   #13 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
You have to practice more if you tells that you use Mxkey from many years,
BTW Check ones again,
When Click Repair SD after load from file, 1 small window opens asking to write from Local RF/BB,
You have to Click No.
Bro.
Just try it, will work for you.
Good Luck...
BR,
ZUBER
Old 10-16-2012, 10:53   #14 (permalink)
Member: 421487
Thanks Meter: 49
after u fallowing instuction but same [secourity test failed pl check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0802E71
ApeCoreSw: V 3.01.1
Using cached productData.
PRIVATE ID: F0D2D98E19757E46E1C2A2A388C8D2B42F7D4E6C
Updating SUPERDONGLE_KEY ...OK
Now you can write RFBB/PM data to the phone.
Done.
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 86 bytes written.
- Key: 4, size 110 bytes written.
- Key: 5, size 4 bytes written.
- Key: 6, size 86 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 86 bytes written.
- Key: 15, size 4 bytes written.
- Key: 16, size 86 bytes written.
- Key: 18, size 86 bytes written.
- Key: 20, size 86 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 16 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
Warning: failed to write 309 - 17 (12 bytes)
Completed in 2.239 s
ApeCoreSw: V 3.01.1
Battery voltage: 4709 mV, current: 77 mA
Language Pack:
- not available.
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 10-16-2012, 11:06   #15 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Your Operation Logs shows, all OK & not from PM side,
Needs to check in details,
Have to Backup RPL PM All Sections,
Erase Phone & Flash it with Latest Version of Phone Product Code, Restore IMEI then manually Write Modified RPL without NPC Data,
Must solve it, if not post result with Logs.
BR,
ZUBER
Page generated in 0.38861 seconds with 7 queries
