02-19-2012, 11:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 338106 Status: Offline Thanks Meter: 55 | 6700c-1 flashing error (SOLVED) CMT ASICID: 000000030000022600010007600C192102011104 EM 1 ID : 00000C34 EM 2 ID : 00000C30 CMT PUBID : 0F9002019B8C0344D6FDD0EFEFC5FAAA0F3A21AA CMT MODE : 00 CMT HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROMID : 3E273BF637BE26FA CMT 1ST Boot OK CMT 2ND Bt: RAPUv11_2nd.fg, Ver: 1.37.1 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAPUv11_algo_xsr16.fg, Ver: 1.40.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm470__13.10.mcusw 00000000: 04 00 00 00 00 B1 72 ......r ERR: CMT FLASH ERASE FLB_MSG_C2: STORE_CERT CER STO Process Failed, Repowering Mobile can any body help me i wrongly post hwk log here is mxkey log bus check log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C08540F2 Using device: HTI, FW ver: 00.50, SN: 00002B41 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 0F9002019B8C0344D6FDD0EFEFC5FAAA0F3A21AA ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0040 - 0000 0031 [Toshiba NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Original Imei: 00000000000000 Original Product code: here is flashing log CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: CABA40E4 [RAP Certificate 145 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT LDSP block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 13.188 s Processing PPM file: rm470__13.21.ppm_c [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400030000000002, 000000A000000028 Partitioning ...OK Erase size: 9.87 MB CMT FLASH,MuxOneNAND area [01F20000-028FFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 17.656 s Processing CNT file: rm470__13.21_008.image_c_eplus_de_87868 [BB5,XSR 1.6] size: 26.75 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Partitioning ...OK Erase size: 195.06 MB CMT FLASH,MuxOneNAND area [02FC0000-0F2BFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 14.766 s Total time for flashing process(boot+erase+write) was 2 min 59.406 s set history is i flashed it with 10.21 later that it is giving this error i have tried several diferent ver Last edited by Mind Power; 02-19-2012 at 11:52. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
