Old 07-20-2010, 14:58   #1 (permalink)
Member: 162328
Sonork: 100.1618216
Thanks Meter: 21
6700c Repair SD Custom loader not available for this ID
Phone Type: RM-470 (Nokia 6700 classic)
SW Version: V 07.90 10-07-09 RM-470 (c) Nokia
Imei plain: 35318103311xxxx
Product Code: 0571197
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353181033113862
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000002
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
i try Repair sd but Custom loader not available for this ID
any solution plz hurry
Old 07-20-2010, 15:00   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
change the flash loader then try maybe work
Old 07-20-2010, 18:16   #3 (permalink)
Member: 180903
Sonork: 100.1637253
Thanks Meter: 70
i have the same problem any solution????????????
Old 07-24-2010, 16:11   #4 (permalink)
kosturon's Avatar
Member: 303652
Thanks Meter: 35
Do you solve your problem???
Old 07-24-2010, 16:47   #5 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
this feature is not supported with any tool in the market
if you want to solved you have to buy rpl
Old 09-13-2010, 17:41   #6 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
Are you sure ? how about ATF ?
Old 09-13-2010, 17:46   #7 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
repair sd for this model
Old 09-13-2010, 22:01   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
not supported atm.
br
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.20207 seconds with 10 queries
