Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Age: 33
Member: 66730 Status: Offline Thanks: 54
| 6700c rm-470 erro flashing dead 6700 rm-470 can't flashed with usb using mxkey any solution? log attached Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm470__10.50.mcusw as MCU [BB5,XSR 1.6] size: 25.15 MB Supported RAP Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2439CE5C RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00000C34 RAP EM1 ID: 00000C30 RAP PUBLIC ID: 1A5002042A630344CC00C8B21D5B4F7846EF6E56 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.48.0 revision: 3.0 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0040 - 0000 0021 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 3.0 size: 0x7F062 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Loader not responding ! Flashing terminated with error(s) in 10.562 s |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks: 1,537
| follow this instruction MXkey Tips and Tricks - HOT SOLUTION ONLY HERE change your loader to new one br, |
| | #3 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: nepal
Member: 564325 Status: Offline Thanks: 77
| Quote:
use any other software to flash set will be ok we already request to fix this issue good luck | |
| | #4 (permalink) | |
| not work Quote:
the same problem | |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 34
Member: 86597 Status: Online Sonork: 100.1602630 Thanks: 610
| The Batter way is Flash ur Phone with ATF |
| The Following User Says Thank You to Ramzan For This Useful Post: |
| | #6 (permalink) | |
| even with mtbox not working Quote:
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: BELARUS, Minsk Age: 33
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks: 1
| Hallo! I have dead 6700c not power on. I've tried fbus flashing - always got this error Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 25100108FB5E034407992C7EFC70A5B21C2D62DE ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0021 - 0000 0023 [ST ] type: NOR,RAP ExtBUSC: 661A F9F7 6003 2384 63E4 A410 70E3 B61F TransmissionMode: 16Bit Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing file: rm470__10.50.mcusw as MCU [BB5,XSR 1.6] size: 25.15 MB Supported RAP Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Storing certificate [NPC, CCC, HWC, R&D] ...Error Erase size: 43.69 MB CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-0009FFFF] CMT MuxOneNAND area [000A0000-0041FFFF] CMT MuxOneNAND area [00420000-0069FFFF] CMT MuxOneNAND area [006A0000-01F1FFFF] CMT MuxOneNAND area [02900000-02FBFFFF] CMT MuxOneNAND area [0F2C0000-0F8BFFFF] Formating Partition ... Formating Partition ... Formating Partition ... Error 0000000000:00 Error Sync! Error 0000000000:00 Error Sync! Flashing terminated with error(s) in 43.016 s RX Buffer: 000000000000000100000000B172 Code: Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm470__10.50.mcusw as MCU [BB5,XSR 1.6] size: 25.15 MB Supported RAP Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 13992EE RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00000C34 RAP EM1 ID: 00000C30 RAP PUBLIC ID: 25100108FB5E034407992C7EFC70A5B21C2D62DE RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.48.0 revision: 3.0 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: FFFF FFFF - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0020 0021 - 0000 0023 [ST ] type: NOR,RAP [ADL] Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 3.0 size: 0x7F062 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Loader not responding ! Flashing terminated with error(s) in 26.407 s |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| FLASH BOX WANTED!!!!!! | J | Wanted Products | 9 | 07-14-2012 20:42 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 05-01-2000 23:28 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
