Old 03-11-2011, 09:19   #1 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
6700c SD REPAIR PROBLEM
6700c sd repair problem
chk with 2 new cables gpg and dits
but not repair
here is log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011)
Product: V 13.21 12-01-11 RM-470 (c) Nokia
SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
ERROR: undefined phoneIDs!
here is scan info
Phone Type: RM-470 (Nokia 6700 classic)
SW Version: V 13.21 12-01-11 RM-470 (c) Nokia
Imei plain: xxxx18103864029-9
Product Code: 0580427
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353181038640299
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000002
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-11-2011, 09:20   #2 (permalink)
ralel's Avatar
Member: 405730
Thanks Meter: 184
maybe not supported hash
Old 03-11-2011, 09:24   #3 (permalink)
Member: 47989
Thanks Meter: 40
no, this is supported!
Any problem... maybe bug
Old 03-11-2011, 10:03   #4 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
bro also try with other tool but not solve
so dont know where is problem
Old 03-11-2011, 10:16   #5 (permalink)
Member: 47989
Thanks Meter: 40
problem is a long cable.
http://forum.gsmhosting.com/vbb/f528...26/index2.html
Old 03-11-2011, 10:43   #6 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 231
sir what version did you used 1.8 or 1.9 try 1.6 or 1.7
Old 03-11-2011, 17:39   #7 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
Originally Posted by ASHIF View Post
maybe copycat solution is not fully tested
bro phone reparied with atf in 1min
Old 03-11-2011, 18:19   #8 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
nice info bro
have tried to repair via cyclone whats the result..??????
Old 03-11-2011, 20:05   #9 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
Originally Posted by ferhel View Post
nice info bro
bro cyclone cant repair this phone i try but not slove finally i use atf and its done
Old 09-12-2011, 07:14   #10 (permalink)
Registered User
Member: 321917
Thanks Meter: 19
Phone type: RM-470 (Nokia 6700 classic)
SW version: V 10.60 12-03-10 RM-470 (c) Nokia
Imei plain: 35694303282189-5
Product code: 0586499
Battery voltage: 4344 mV, current: 135 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
Imei net: 356943032821895
Counter: 0/3, 0/10
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
we same problem.. maybe mx bug...
Old 09-14-2011, 01:53   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
no such bugs. please see the date of post start.
now all rapuyama SD repair is supported thru HTI.
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.19853 seconds with 9 queries
