05-11-2010, 08:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 6700c security code cannot detect in usb data cable need help |
The Following User Says Thank You to lilong_lee For This Useful Post: |
05-11-2010, 08:49 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | simple, insert fbut cable in phone and press power on, then when phone show test mode, dont remove, insert usb cable and you can reset |
05-11-2010, 08:50 | #4 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | any have idea mr manoli regarding for 6700c have security code then not fogot a pasword how to connet in via usb data cable even i try to turn off the mobile then put again and fresh in connect cannot show the 6700c need your help |
05-11-2010, 08:51 | #5 (permalink) | ||
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
cannot understand your saying bro | ||
05-11-2010, 08:56 | #7 (permalink) |
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | this is what you do, perform this using jaf, insert phone fbus cable, dont click check press power on botton on phone phone will show test mode or it will rather power on (in this case just manual select test mode in the drop down meu when test mod show on display insert usb cable and switch to usb mode you can read info and reset code |
05-11-2010, 08:59 | #8 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | but i have no jap only mx key and hwk so what we do this my using cable is universal cable so need help |
05-11-2010, 09:07 | #9 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | mr manoli we need your responece here about using cable to detect local mode and test mode usually 6700c have no cable only universal cable but when i try universal cable cannot detected even i try to use latest universal cable need your good anwere here mr. manoli next add usb data cable to detect local mode and test mode for this mobile |
06-02-2010, 15:30 | #11 (permalink) |
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Ok here is a trick, put a 4.7k resistor between bat - and bsi, put battery, press power on, you will get local mode on phone, connect usb cable and do job. |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
