03-18-2010, 20:17 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 44
Member: 164505 Status: Offline Thanks Meter: 16 | 6710 only memory full i have 6710 show only memory full do not open >>> like startup failuer i flash it = no way erase = no way erease npc = no way try to format it manual with ( *+3+ok+power ) = no way it is do not make test or local mode >>> so do not make format this is info mx_key Phone Type: RM-491 (Nokia 6710) SW Version: V ICPR82_09w36.5 09-10-09 RM-491 (c) Nokia Imei plain: 35420103118079-3 Product Code: 0571518 ApeCoreSw: 022.013 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354201031180793 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF please help me to solve this problem ... thankes |
03-28-2011, 00:38 | #6 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Newcastle,Australia Age: 47
Member: 44167 Status: Offline Thanks Meter: 17 | Hi I had the same trouble and i flashed it with hwk with the same product code and i still had the same trouble until i did the ui settings each of them manually by doing them all one by one try and post the result here best of luck Faisal |
6710 only memory full | mory2 | Nokia Base Band 5 ( BB-5 ) | 5 | 08-09-2011 07:32 |
Area Display- Active Channels Memory full only with "Idea" SIM | Raccoon | Motorola P2k | 0 | 04-20-2007 20:50 |
Motorola L7+ memory full and cannot read memory card | GSMaxx | Motorola P2k | 1 | 04-09-2007 10:53 |
nokia7650 memory full problem | Banna | WD2 & APE (Symbian Phones) | 1 | 10-06-2002 05:29 |
