03-11-2010, 09:21 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: CHINA Zhuhai Age: 40
Member: 760531 Status: Offline Sonork: [email protected] Thanks Meter: 58 | 6730C (RM-566) write failure. Request help Version from phone: 023.010 Version from file: 023.010 Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 29200107065D0344D3674A651E83A4EB182FAF94 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 2E20 2020 2020 2020 2020 2010 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. Reading RAP NPC (0x0 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Flash Imei: 00000000000000 NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.3\data\backup\BB5_00000000000000_BA CK.rpl" Processing file: rm566_023.010_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 88.26 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 29200107065D0344D3674A651E83A4EB182FAF94 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 6163 C6F8 AEF0 2F59 38BF 9C2A 986C 962D ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. Total erase size: 64.00 KB CMT ONENAND area [00020000-0003FFFF] CMT ONENAND area [00060000-004DFFFF] CMT ONENAND area [008E0000-0B93FFFF] Format NAND erased in 0.063 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 32.000 s RX Buffer: C7012D0103CD00 Scan normal Phone Type: RM-566 (Nokia 6730c) SW Version: V ICPR82_09w39.1 06-10-09 RM-566 (c) Nokia Imei plain: 35421203179085-3 Product Code: 0588679 ApeCoreSw: 023.010 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354212031790853 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-11-2010, 09:59 | #3 (permalink) |
Member: 760531 Status: Offline Sonork: [email protected] Thanks Meter: 58 | Thanks! Has been successfully repaired Phone Type: RM-566 (Nokia 6730c) SW Version: V ICPR82_09w39.1 06-10-09 RM-566 (c) Nokia Imei plain: 35421203179085-3 Product Code: 0588679 ApeCoreSw: 023.010 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354212031790853 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
6730 rm-547 ---> RM-566 convertion | pitone02 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 10-10-2010 11:38 |
N95 rm-159 startup failur contact retailur | Mallick Manzil | Nokia Base Band 5 ( BB-5 ) | 1 | 07-24-2009 06:55 |
VYGIS KU990 Failure to help unlock request | shen690 | VygisToolbox | 2 | 12-05-2008 15:12 |
N95 - RM-160 flash files request | mtb116 | Universalbox | 0 | 04-09-2008 08:45 |
