Member: 682736
Thanks Meter: 457 | 6730c shows Memory full and restart.(ANSWERED) I downloaded latest version files from server. I flashed but phone is still in problem... Phone starts and after few seconds shows Memory full and restarts.... I also formated holding *, 3, call and power on.... Quote:
MXKEY Serial: [OM****Y AG Smart Card Reader USB 0] - C0802125
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.70
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Reading Important data ...
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35421203608926_BA CK.rpl).
Processing MCU file: rm566_031.022_prd.core.fpsx
[BB5,XSR 1.6] size: 91.24 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104
Battery voltage: 3768 mV
Warning battery voltage is less, phone might not detected after flash !
Phone type: RM-566 (Nokia 6730c)
Product code: 0582396
SW version: 023.010
LanguagePkg version: 023.010023.010.11.01023.010.C01.01
Version from phone: 023.010
Version from file: 031.022
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 185C5ED5
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
CMT EM0 ID: 00000C34
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 203000148E3C0E49B019321271E382202CE3882B
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT ROM ID: 3E273BF637BE26FA
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35421203608926_CE RT.rpl"
CMT PAPUBKEYS HASH: 397DCE210733C335E84BAD369EC893FCA06D1BC3
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 181.06 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0B93FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 397DCE21 [RAP Certificate 210 v1] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 17.953 s
Processing PPM file: rm566_031.022_11.01_MEA_C_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 34.79 MB
Erase size: 51 MB
CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 6.859 s
Processing PPM file: rm566_031.022_C01.01_BLACK_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 8.36 MB
Erase size: 25 MB
CMT FLASH,MuxOneNAND area [0A040000-0B93FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 1.734 s
Processing CNT file: rm566_031.022_U000.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 528.28 KB
Erase size: 61 MB
CMT FLASH,MuxOneNAND area [0B940000-0F63FFFF]
Programming completed in 0.578 s
Processing CNT file: RM566_APE_ONLY_ENO_09w26_v0.024.fpsx
[BB5,XSR 1.6] size: 2.28 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [004E0000-008DFFFF]
CMT SOS*ENO block sent
Programming completed in 0.500 s
Total time for flashing process(boot+erase+write) was 36.187 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 6730 classic USB Phonet, PORT_ID: 1A449B0
Verifying communication to device OK.
SW version: V ICPR82_10w08 26-02-10 RM-566 (c) Nokia
Imei plain: 35421203608926-9
Battery voltage: 3766 mV, current: 178 mA
ApeCoreSw: 031.022
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354212036089269
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.297 s
