06-17-2009, 11:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: ROMANIA/Alexandria Age: 44
Member: 230301 Status: Offline Sonork: 100.106864 Thanks Meter: 1,434 | 7070 prisma no signal Processing file: rh116__06.82.mcusw ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:3B8ADA60 Programming MCU ... rh116__06.82.mcusw: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 9.69 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01000000-0101FFFF] erased in 1.328 s Area [01020000-01C3FFFF] erased in 2 min 4.187 s Flash programming ... Error finalization ! Programming completed in 2 min 40.297 s File Processed in 5 min 4.329 s Processing file: rh116__06.82.image_ee ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:C5A4DA78 Programming Content Pack ... rh116__06.82.image_ee: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] page size: 128 K size: 3.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [02000000-02DBFFFF] erased in 4 min 34.766 s Area [02DC0000-02F9FFFF] erased in 38.594 s Converting UCP blocks to 128 K. Flash programming ... Error finalization ! Programming completed in 1 min 53.875 s Content extract fail, continue anyway ... File Processed in 8 min 52.750 s Processing file: rh116__06.82.ppm_ee ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:2984DA60 Programming PPM ... rh116__06.82.ppm_ee: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 2.75 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01C40000-01FFFFFF] erased in 38.078 s Flash programming ... Error finalization ! Programming completed in 1 min 28.375 s File Processed in 2 min 19.156 s Flashing completed in 17 min 17.156 s Phone Type: RH-116 (Nokia 7070d-2) SW Version: V 06.82 26-09-08 RH-116 (c) Nokia Imei plain: 35637902092281-9 Imei OTP: 35637902092281 Product Code: 0558876 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: EE Language Pack: - not available. Total time to process is 17 min 23.843 s |
06-17-2009, 21:55 | #5 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
Code: Processing file: rh116__06.82.mcusw ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:3B8ADA60 Programming MCU ... rh116__06.82.mcusw: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 9.69 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01000000-0101FFFF] erased in 1.328 s Area [01020000-01C3FFFF] erased in 2 min 4.187 s Flash programming ... Error finalization ! Programming completed in 2 min 40.297 s File Processed in 5 min 4.329 s Processing file: rh116__06.82.image_ee ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:C5A4DA78 Programming Content Pack ... rh116__06.82.image_ee: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] page size: 128 K size: 3.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [02000000-02DBFFFF] erased in 4 min 34.766 s Area [02DC0000-02F9FFFF] erased in 38.594 s Converting UCP blocks to 128 K. Flash programming ... Error finalization ! Programming completed in 1 min 53.875 s Content extract fail, continue anyway ... File Processed in 8 min 52.750 s Processing file: rh116__06.82.ppm_ee ASIC ID: 0x3162 [UPP8M_v6.x] u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0054B720:2984DA60 Programming PPM ... rh116__06.82.ppm_ee: [DCT4,DCT4 ALGORITHM,DCT4 ALGORITHM] size: 2.75 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 Area [01C40000-01FFFFFF] erased in 38.078 s Flash programming ... Error finalization ! Programming completed in 1 min 28.375 s File Processed in 2 min 19.156 s Flashing completed in 17 min 17.156 s br, | |
The Following User Says Thank You to Andra For This Useful Post: |
06-17-2009, 23:20 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | brother but whenever i want to connect ufs with mx key .. it cant show .. but when i connect jaf .. it works well.? whats the problem why i cant connect ufs with mx key? |
How to unlock 7070 prisma | gerbang_cell | MT-BOX | 3 | 02-07-2011 17:04 |
Help... Nokia 6600 - no signal on speaker, no signal on buzzer. | Normunds | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 08:20 |
6310 No Signal No Signal | frandau | Nokia Hardware & Hardware Repair | 1 | 05-18-2005 11:40 |
nokia phones with network+full signal then NO SIGNAL AND NO NETWORK NAME .!! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-22-2002 15:20 |
