06-03-2010, 09:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | 7100 imei change i have to change imei for 7100s rm-438, is it possible? |
The Following User Says Thank You to LEENO For This Useful Post: |
06-03-2010, 20:27 | #3 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | with method1 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C8060C:3B8ADA60 it stop here -------------------------------------- with method2 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.0 SERVER: Not a valid IMEI number ( |
06-04-2010, 10:02 | #4 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C8060C:3B8ADA60 Programming FLASH Imei ...failed |
06-04-2010, 20:53 | #5 (permalink) |
Member: 38084 Status: Offline Thanks Meter: 115 | where is support? In version 3.2 imei change was working, now i activated dct4plus and imei change not working. And i can't install 3.2 because require old server for signing .... |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
