02-20-2010, 15:52 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | before you did the unlock was it working well in organizer?maybe phone has that problem even before you did unlock process...anyways try to format or do full factory and if not fixed do full flashing |
02-20-2010, 16:24 | #4 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 530442 Status: Offline Thanks Meter: 11 | Imei net: 35321703018062 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN PhoneType:RM-438 SwVersion: V 05.41 26-11-08 RM-438 (c) Nokia MCU file: rm438__05.41.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C72D77:3B8ADA60 Area [01000000-0101FFFF] erased in 1.078 s Area [01220000-0123FFFF] erased in 1.079 s Area [01440000-0145FFFF] erased in 1.063 s Area [014A0000-014BFFFF] erased in 1.078 s Area [01C00000-01C1FFFF] erased in 1.079 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 40.954 s Reading Simlock info ... Imei net: 35321703018062 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
02-22-2010, 00:32 | #8 (permalink) |
No Life Poster Join Date: May 2002 Location: dont ask!
Member: 12411 Status: Offline Sonork: 100.113572 Thanks Meter: 813 | @Dudiso all you need to do is reflash your phone then unlock and do a fullfactory setting.. br freddy www.gsmph.com |
02-22-2010, 03:23 | #11 (permalink) |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | this is bug unlock all dct4 plus.. after unlock ok..but when i click organiser shut down phone like 7100s 1680c 2630 2600c.. froblem is unlock patch ecryted unlock.. flash not working.. sulotion is full erase and write pm.. but us of now i m using unlock ub.. |
>::nokia 7100s dead after unlock plzz help >:: | ^^^RAVI SOOD^^^ | Nokia Base Band 5 ( BB-5 ) | 22 | 07-06-2013 04:07 |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
Plezzzzz help Nokia 7100 dead after unlocking with UB.... | nofear99 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-15-2010 04:48 |
7100s problem after unlock | service4gsm | Universalbox | 3 | 04-18-2009 22:05 |
