07-09-2010, 08:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | 7210 after flash dead and again bus check Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 167001120FAC8A56E7B213D878D685184607A30A ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Original Imei: 00000000000000 Original Product code: if i try to flash manually select file ,and press flash this the log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm436__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.06 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 167001120FAC8A56E7B213D878D685184607A30A ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.078 s CMT NOR area [000006C0-0001FFFF] erased in 0.157 s CMT NOR area [00040000-000BFFFF] erased in 0.163 s CMT NOR area [000C0000-0013FFFF] erased in 0.183 s CMT NOR area [00140000-0119FFFF] erased in 0.236 s CMT NOR area [011A0000-0133FFFF] erased in 0.191 s Flash programming ... Error chk C7012D0103CD000090000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00000400, Result: 0090 Flashing terminated with error(s) in 29.499 s RX Buffer: C7012D0103CD000090000000F172. |
07-09-2010, 08:51 | #3 (permalink) | |
Member: 334773 Status: Offline Thanks Meter: 92 | Quote:
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm411__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 19.92 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1FB998E3 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 07F00005B8E15850CF1381DF5CA25C3C617FCE77 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4AF40 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 39.080 s pooling for ADL l device WHILE TIME WE HAVE TO DO ANYTHING SIR . | |
07-09-2010, 13:03 | #7 (permalink) |
Member: 334773 Status: Offline Thanks Meter: 92 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm411__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 19.92 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 07F00005B8E15850CF1381DF5CA25C3C617FCE77 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.075 s CMT NOR area [000006C0-0001FFFF] erased in 0.153 s CMT NOR area [00040000-000BFFFF] erased in 0.152 s CMT NOR area [000C0000-0013FFFF] erased in 0.166 s CMT NOR area [00140000-0137FFFF] erased in 0.265 s CMT NOR area [01380000-0151FFFF] erased in 0.153 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00040000, Result: 0010 Flashing terminated with error(s) in 29.538 s RX Buffer: C7012D0103CD000010000000F172 sir plz help me |
07-10-2010, 08:14 | #8 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
You have to wait Alim to answer you, he is the programmer and he know all the errors in his software, hope he will come online in forum to answer. BR, Manole | |
07-16-2010, 08:21 | #9 (permalink) | |
Freak Poster Join Date: May 2010 Location: Zogam
Member: 1299960 Status: Offline Thanks Meter: 36 | Quote:
07-16-2010, 08:41 | #10 (permalink) |
Freak Poster Join Date: Jul 2007 Location: soon mars colony 2050 Age: 41
Member: 552857 Status: Offline Thanks Meter: 19 | use higher version,make sure you tick the cnt...file.use full battery and dont forget to put the charger while flashing.................. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
