01-13-2010, 15:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | 7210 C Auto Power Off ( if set is on charging then it will not shut down) |
01-13-2010, 20:10 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,473 | maybe ur phone super dongle key cruppted. always post full details with scan and bus check log for to get better help |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
01-13-2010, 21:27 | #4 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: sabageria
Member: 207455 Status: Offline Thanks Meter: 35 | Quote:
Cheers | |
01-26-2010, 10:30 | #7 (permalink) | |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
Library version: 1.0.0.11813, Date: 21-01-2010 Device found: nmwcdnsuc\Nokia USB Flashing Generic Nokia USB Flashing Generic ready. Nokia USB Flashing Generic detached. Processing file: rm436__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.06 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: EF69EC2 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 26E00104A7087D56F857A44C5F8D10E8F0E363B5 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes [ADL] Update Server code succesfully sent to phone Nokia USB Flashing Generic detached. [ADL] Pooling for ADL device Device changed, found new Instance: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 16283CEF [ADL] Verifying communication to device OK. Total erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.703 s CMT NOR area [000006C0-0001FFFF] erased in 0.703 s CMT NOR area [00040000-000BFFFF] erased in 3.047 s CMT NOR area [000C0000-0013FFFF] erased in 2.594 s CMT NOR area [00140000-0119FFFF] erased in 1 min 37.547 s CMT NOR area [011A0000-0133FFFF] erased in 9.625 s Flash programming ... CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) written. Programming completed in 1 min 1.703 s Processing file: rm436__07.23.ppm_ma as PPM [BB5,BB5 ALGORITHM] size: 6.04 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Total erase size: 8.62 MB CMT NOR area [01340000-01BDFFFF] erased in 49.094 s Flash programming ... Programming completed in 20.765 s Processing file: rm436__07.23.image_ma_sa as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 21.02 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Total erase size: 35.87 MB CMT NOR area [01BE0000-01F7FFFF] erased in 22.172 s CMT NOR area [01F80000-03FBFFFF] erased in 3 min 12.297 s Flash programming ... Programming completed in 1 min 11.109 s [ADL] Pooling for ADL device [ADL] Timeout, no device not found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia 7210 Supernova USB Generic, ID: 2B9F443B [ADL] Verifying communication to device OK. Flashing completed in 10 min 51.109 s Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 3519620********* Product Code: 0566914 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3519620******** Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 10 min 54.672 s Now what should be the possible cause and solution for this ? | |
02-17-2010, 16:45 | #8 (permalink) |
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | This set is still in the same state....flashed with other firmwares but same....all is ok but set turns off after a few mints.... but if i keep charger plugged in it will not shutdown or restart..... any body has the solution or atleast the reason ? Br |
10-17-2012, 14:53 | #9 (permalink) | |
Junior Member Join Date: Feb 2008
Member: 709762 Status: Offline Thanks Meter: 0 | i have same problem Nokia 7210 (Autofone Swith off,Not Swith offWhen In Charging) Quote:
10-17-2012, 14:59 | #10 (permalink) | |
Member: 709762 Status: Offline Thanks Meter: 0 | I Have Same Problem In 7210 (AutoSwith Off,WhenCharge Connected Not Swith Off) Quote:
10-17-2012, 15:02 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BTW It's Hardware, So Check or Change Bluetooth or Avilma IC, Battery Voltage Drops Quick mainly due to this 2 IC's Check & Clean for Waterlogs, Must solve yours. BR, ZUBER | |
*7210 supernova auto shut off successfully done via usb cable* | GELANEROB | Universalbox | 2 | 12-09-2008 18:26 |
Siemens C30 v2.4.0 Auto Power OFF 3, 4 sec | -=G3=- | x1x to x45/x50 | 2 | 03-08-2002 06:00 |
BE1 - 16D Auto power off | rayback | Alcatel & TCL Old Models | 0 | 02-25-2002 06:27 |
v8088 auto power off | acyl2000 | Motorola Old Legacy (EMMI) | 6 | 10-18-2001 03:48 |
3310 auto power off 100% solution | Fai555 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-07-2001 11:59 |
