02-19-2010, 06:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: MX-KEY is the BEST NOKIA TOOL
Member: 965510 Status: Offline Thanks Meter: 8 | 7210 s no network after repairing contact service and the log is Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35196203296453-4 Product Code: 0514950 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351962032964534 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-19-2010, 06:48 | #2 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | Quote:
02-19-2010, 07:05 | #4 (permalink) |
Member: 965510 Status: Offline Thanks Meter: 8 | Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request showing this err |
02-19-2010, 07:11 | #5 (permalink) |
Member: 59732 Status: Offline Thanks Meter: 47 | used super sd auth then wite full modified pm problem can be solved |
The Following User Says Thank You to div_raj For This Useful Post: |
02-19-2010, 07:13 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | 7210c superdogle key & Contact Service Successfully Repaired with Mxkey Video Manual Quote:
Here I am providing Succeesfully Repaired superdongle key, Simlock data, contact service video manual here download. Say thanks. Link Below. http://www.mediafire.com/?ltzdwzmn2ny | |
The Following 3 Users Say Thank You to swechacnu For This Useful Post: |
02-19-2010, 07:40 | #9 (permalink) |
Member: 965510 Status: Offline Thanks Meter: 8 | selftest log here Phone Type: RM-436 SW version: V 07.23 17-07-09 RM-436 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
02-19-2010, 07:46 | #10 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Split / Zagreb, Age: 15
Member: 1212935 Status: Offline Sonork: cylone team Thanks Meter: 122 | try this method and make sure you use good pm files.,.. http://forum.gsmhosting.com/vbb/show...5&postcount=20 |
02-19-2010, 07:50 | #11 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Narowal
Member: 207708 Status: Offline Sonork: 100.1602241 Thanks Meter: 1,005 | reflash Quote:
04-23-2010, 15:53 | #14 (permalink) |
Freak Poster Join Date: Jan 2007 Location: @ planet EARTH
Member: 433173 Status: Offline Sonork: 100.1590587 Thanks Meter: 31 | 7210c no network the problem is still the same... self test shows:- Code: Phone Type: RM-436 SW version: V 07.23 17-07-09 RM-436 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N !no signal 44 LPRF_AUDIO_LINES N !no signal 2 CURRENT_CONS N passed 42 RADIO N !no signal 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N !no signal 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N !failed ! 83 CDSP_RF_SUPPLY N !failed ! 80 CDSP_TX_PLL_PHASE_LOCK N !failed ! 81 CDSP_RX_IQ_LOOP_BACK N !failed ! 77 CDSP_GSM_TX_POWER N !failed ! |
7210c after repair contact service no network (CLOSED, OLD THREAD) | fretburner | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 08-13-2011 09:16 |
No Network after Repaire Contact service | webshawk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-23-2010 16:05 |
5220 after repair contact service resrart | amin1999 | Universalbox | 21 | 01-11-2010 15:48 |
Strange problem after repairing Contact Service in 8310 | kingofhearts | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-01-2002 03:59 |
c25v49 no network after repair with bartek | sidharthaharish | x1x to x45/x50 | 2 | 12-16-2001 13:38 |
