10-04-2011, 20:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | 7210 SIMLOCK invalid! ## (ANSWERED) scan Code: Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35523103161190-0 Product code: 0566808 Battery voltage: 4883 mV, current: 66 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid Failed to read SP data Code: Failed to read SP data MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C085844F Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData. PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 PRIVATE ID: 921366C5F149E4A21DB29B2B9C770AEFCD139628 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data |
10-04-2011, 20:43 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | post the logs fully when you're doing this: - Imei & Security > Simlock > Mark PA_SL2 > Mark Make Simlock RPL > choose Repair Simlock > click Update SPLock. Work around on any next error: - backup RPL: select RAP - full erase: get addr, don't mark safe erase. ERASE! - reflash, restore imei, make repair simlock, make repair sd, make DCC also. BR |
10-04-2011, 21:28 | #3 (permalink) |
Member: 78657 Status: Offline Thanks Meter: 71 | - Imei & Security > Simlock > Mark PA_SL2 > Mark Make Simlock RPL > choose Repair Simlock > click Update SPLock. Code: Failed to read SP data MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C085844F Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData. PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 PRIVATE ID: 921366C5F149E4A21DB29B2B9C770AEFCD139628 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data backup RPL: select RAP Code: Reading RPL backup ... Reading CERT data ... CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35523103161190 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35523103161190_BACK.rpl" - full erase: get addr, don't mark safe erase. ERASE! Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C085844F Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Erase size: 64 MB CMT FLASH,NOR area [00000000-03FFFFFF] erased in 3.969 s Prog.status for Asic CMT ... NOR: Success Erase size: 64.25 MB CMT FLASH,NOR area [00000000-03FFFFFF] erased in 0.610 s CMT FLASH,NOR area [03FC0000-03FFFFFF] erased in 0.015 s Prog.status for Asic CMT ... NOR: Success - reflash, restore imei, make repair simlock, make repair sd, make DCC also. Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C085844F Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0119FFFF] CMT FLASH,NOR area [011A0000-0133FFFF] erased in 0.187 s Prog.status for Asic CMT ... NOR: Success Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: Success Programming completed in 1 min 38.437 s Processing PPM file: rm436__07.23.ppm_c [BB5,BB5 ALGORITHM] size: 7 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Code: RPL: "C:\mobileEx\3.5\data\backup\BB5_35523103161190_BACK.rpl" Imei: 35523103161190 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NOR: Success Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35523103161190-0 Battery voltage: 4792 mV, current: 63 mA Code: Failed to read SP data MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 5] - C085844F Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData. PUBLIC ID: 2150010E6A4A7F56CA70BC26AE44940266FA54D3 PRIVATE ID: 921366C5F149E4A21DB29B2B9C770AEFCD139628 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data |
10-04-2011, 22:04 | #4 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Hi, repeat repair, delete first your caches: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\productdata.xml no such bugs, all should be done very easy. also check your cable and pins. when you got "warning blabla..SL3 phone, just give answer YES" Code: MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 0] - C0696666 Using device: HTI BOX, FW ver: 00.24 Connection status: NUSB3XHC:NUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 52.99 KB Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Sending Overflow Loader(0x2E4 bytes) ... Overflow loader running .. Sending CustomLoader ...OK PUBLIC ID: 20800006918D7D56CE5C3600FC3958A8421384EE PRIVATE ID: 08551610193E457463EAB322E841BFF875E2AB4E E-FUSE: 025B2301 SEC ROM CRC: 40830040 Updating SIMLOCK...OK Reading Simlock info ... Imei net: 353180032349998 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-05-2011, 10:08 | #5 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Bangladesh
Member: 671937 Status: Offline Sonork: 100.1613181 Thanks Meter: 94 | I also faced this problem with 7210.......... "SIMLOCK invalid!"........when try Imei & Security > Simlock > Mark PA_SL2 > Mark Make Simlock RPL > choose Repair Simlock > click Update SPLock.............."warning: this phone is detected as SL3 phone, if you are sure not SL3 phone then you can ignore this message".......i give answer YES.............done erase, reflash, restore imei, make repair simlock, make repair sd, make DCC also...........but always "SIMLOCK invalid!"........... i returned phone to customer.........but i dont understand why problem not solved & what is the actual problem............. |
Invalid sim on Nokia 6210 | dario | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-23-2001 02:19 |
Nokia 3210 Mastercode +simlock | kraaiguy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-26-2000 14:13 |
SIMLOCK NOKIA 3210 V 4,43 | zibiss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-23-1999 23:18 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
N6150 simlock open??? | Tommy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-21-1999 09:31 |
