02-15-2010, 18:09 | #1 (permalink) |
Insane Poster Join Date: Mar 2008 Location: algeria
Member: 729517 Status: Offline Thanks Meter: 12 | 7210c and 5220 contacte sevices sloved Info regarding 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process thank you Info regarding 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process Info regarding 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process thank you manole thank you hasnaine |
The Following 5 Users Say Thank You to bensbaa05 For This Useful Post: |
02-16-2010, 07:57 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
02-16-2010, 08:37 | #6 (permalink) |
Registered User Join Date: Apr 2008 Location: Goyang City
Member: 751390 Status: Offline Thanks Meter: 18 | |
02-17-2010, 05:01 | #9 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | hello guys sorry for truble i have changed the battary then charging indication is well so it is my fault for 7210c charging not supported thanks all bro |
full PM readed from working 7210c and 5220 needed urgently | GOODNESS | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-11-2010 00:13 |
5220 and 3600s Contac sevice | rebi_cell | Nokia Base Band 5 ( BB-5 ) | 1 | 11-11-2009 06:34 |
7210c contact sevice | taieeb | Nokia Hardware & Hardware Repair | 6 | 10-17-2009 11:06 |
5220 contact sevice can't repair sl,,help | kirta | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 09-14-2009 19:07 |
