Old 07-09-2011, 14:50   #1 (permalink)
unlockers555's Avatar
Member: 547368
Thanks Meter: 254
Arrow 5130 blink-white sceen-restart can't solw by flashing.....why (ANSWERED)?
i expireance this since last 1-2 months,i get many nokia 5130 with problem blink-restart-white screen.
i try to solw this by flashing with letest version v7.97
also with lower version, but everytime i am fail.
softwere is load done(flashing is ok) but no luck as same problem as it befor.
i want to know that this is just my foult or many technisions face this.
and how to solw this ?
The Following User Says Thank You to unlockers555 For This Useful Post:
Old 07-09-2011, 18:47   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
same problem face in nokia 5130 2700 2690 but i m not solv this problen in softwer
Old 07-09-2011, 19:13   #3 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
This is the most common problem with 5130c & 2700c. The most problem is come from the RAP IC, and 99% this problem happen to samsung RAP IC.
Try to reheat or change the RAP IC, your problem will solved.
good luck.
Old 07-10-2011, 07:34   #4 (permalink)
Member: 171342
Thanks Meter: 36
REMOVE CAMERA THEN CHECK IF NOT SOLVE REHOT MMC IC IF NOT SOLVE REMOVE ALL CHANGE DISPLAY IF NOT SOLVE REMOVE ALL SHEILDS & CAMERA CLEAN BOARD WITH LITLE SOAP oR SOAP SOLUTION & LOTS OF WATER & THEN FOR DRYING IN DIRECT SUNLIGHT FOR 1 TO 1/2 HOURS THEN AGAIN CLEAN PCB WITH WHITE PETROL OR IP OR CTC WITCH EVER U USE THEN LITEL REHOT FULL PCB THEN CHECK UR PHONE & GV ME RESULT
Old 07-11-2011, 20:59   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
such phone with the same HW configuration are buggy on flash chip.
- reheat, reball. if not helped, backup, change flash chip, reflash, restore.
Old 07-12-2011, 12:20   #6 (permalink)
Member: 1524461
Thanks Meter: 26
bro dont waste your time .
its a rap ic problem .
out of 20 mobile only one is success.
some time mobile get full dead also.
i advice do this job when you free time
Old 07-12-2011, 13:04   #7 (permalink)
Member: 671476
Thanks Meter: 31
at last...... change the phone..
Old 07-13-2011, 06:43   #8 (permalink)
Member: 547368
Thanks Meter: 254
Arrow what an answer ..!!
hahahahahahahahahahahahahahahahahahahahaa......... .....................
Old 08-13-2011, 08:46   #9 (permalink)
Member: 777000
no solution for than please answer any one
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.26164 seconds with 10 queries
