12-20-2012, 08:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | 7210c auto restart solved by mxbox via windows 8 os picture here logs here Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: ernie78 Using device: USB ROM and HTI, FW ver: 00.50, SN:ernie78 Connection status: EHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 2360000B11145950DE6347586D2160D72E18BB93 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: A0E4184 Verifying communication to device OK. Erase size: 19.12 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.842 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.860 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 3.467 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.543 s CMT FLASH,NOR area [00140000-0119FFFF] erased in 1 min 35.532 s CMT FLASH,NOR area [011A0000-0133FFFF] erased in 8.833 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 18.193 s Processing PPM file: rm436__07.23.ppm_a [BB5,BB5 ALGORITHM] size: 6.69 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01340000-01BDFFFF] erased in 47.301 s Flash programming ... Programming completed in 55.918 s Processing CNT file: rm436__07.23.image_a [BB5,BB5 ALGORITHM] page size: 128 K size: 22.03 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT FLASH,NOR area [01BE0000-01F7FFFF] erased in 27.453 s CMT FLASH,NOR area [01F80000-03FBFFFF] erased in 4 min 4.199 s Flash programming ... Programming completed in 2 min 45.343 s Total time for flashing process(boot+erase+write) was 13 min 55.260 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 7210 Supernova USB Phonet, PORT_ID: 37B93FA6 Verifying communication to device OK. Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35931002217818-0 Product code: 0564805 Battery voltage: 4021 mV, current: 64 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359310022178180 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! br |
The Following 5 Users Say Thank You to ernie78™ For This Useful Post: |
12-20-2012, 09:53 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Yesterday i gave advice to a user to Install Mxkey on Windows8, waiting for reply, Updated Drivers of Latest Mxkey Ver3.5 Rev2.5 must work for it & now it's Confirmed. That means, it's good News for Mxkey users, Mxkey support on Window8 OS. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-20-2012, 10:46 | #4 (permalink) | |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
full working on windos 8 wow thanks br: ernie78 | |
