03-17-2010, 19:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | 7210c Big Problem Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35XXXXXXXXXXXXX Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35XXXXXXXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone showing contact service, I try following things. 1)sx4 service and write good modified PM but problem not solvd. 2)Go to serves>imei&securty>imei rebuild>repair sd then go to pm >click sd auth & write pm (Modified good PM ) 3) recover cert but i got error like this Connecting to server ...OK, Login ... ERROR: No certificate found in the database ! Please Help me Step by step, Thanks in advance. Good modified Pm file attached here. I'm waiting here. Last edited by uttam4u2002; 03-17-2010 at 19:56. Reason: correction |
03-17-2010, 20:06 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | 1 back rpl 2 full erase on mxkey 3 flash phone 4 writ rpl 5 mxkey>serves>imei&securty>imei rebuild>repair sd 6 go to pm >click sd auth writ pm (wait 2mnt) 7 full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
03-17-2010, 22:18 | #4 (permalink) | |
Member: 231153 Status: Offline Thanks Meter: 313 | Quote:
writ this rpl 4shared.com - online file sharing and storage - download 7210c_without_NPC_DATA__made_by_MxKey.rpl then mxkey>serves>imei&securty>imei rebuild>repair sd go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt full factory | |
03-17-2010, 22:27 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | Yes s @alasmmar said that.. Just write Attached rpl then write (1,309 field)pm |
The Following 3 Users Say Thank You to Jr Telecom For This Useful Post: |
03-17-2010, 22:29 | #6 (permalink) |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Thank you very much alasmmar brother, just i write u r rpl file and do full factory setting my problem solved. now my phone working Good. Once again thanks brother for u r Gr8 help. Here is Log.....brother.........alasmmar Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35XXXXXXXXXXXXX Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35XXXXXXXXXXXXX Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by uttam4u2002; 03-17-2010 at 22:31. Reason: correction |
The Following User Says Thank You to uttam4u2002 For This Useful Post: |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
Jaf big problem | haytham_84 | J.A.F. By Jafsupport.com | 0 | 03-29-2010 20:53 |
6085 big problem | kami1987 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 13:42 |
7210c big problem | mani pkm | Nokia Hardware & Hardware Repair | 3 | 06-10-2009 16:00 |
