Old 12-18-2010, 15:36   #1 (permalink)
Member: 457271
7210c CMT PAPUBKEYS is blank/erased. (ANSWERED)
Dear All
i flash 7210 supernova with Mx Key
after that the set shows like this
this is 2 nd time
last set was 3110c like same problem
pleas help me anybody
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 19200014525F575049BBE25D2B4462CFD70158D8
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
Old 12-18-2010, 15:45   #2 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
Originally Posted by uvrajs View Post
Dear All
this is 2 nd time
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
use 7pin cable and post result
Old 12-19-2010, 00:13   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hello,
always use latest firmware available.
last version for both phone with you 3110 and 7210 is 7.23
Old 01-12-2011, 03:43   #4 (permalink)
Member: 106488
Thanks Meter: 24
7210 any signal please help
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 19D00015BF837C56EA21EF26990545E1AA62A1ED
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
No RAP Flash Chip Detected
Old 01-12-2011, 05:38   #5 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
use another flasher like jaf and your problem will solv i will try it many time
Old 01-12-2011, 05:45   #6 (permalink)
neo_2005's Avatar
Member: 65656
Thanks Meter: 91
Maybe u can look this
Old 01-12-2011, 05:45   #7 (permalink)
Member: 471657
Thanks Meter: 7
No ,its imei erased do not run only solve rpl writing solve this problem
Old 01-12-2011, 06:00   #8 (permalink)
swechacnu's Avatar
Member: 115144
Sonork: 100.1590698
Thanks Meter: 498
Dear All
this is 2 nd time
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Br,
You can flash with mxkey 3.4 rev 1.7 your problem solved 100%, because new update some bugs on there so you can use old mxkey 3.4 rev1.7. if you after any problem with this you can contact me [email protected], i will solv ur problem with team viewer.
BR,
Srinivas Reddy.
Old 01-12-2011, 06:08   #9 (permalink)
neo_2005's Avatar
Member: 65656
Thanks Meter: 91
Let see ,
Ur log cant see flash chips,
Normaly,
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Maybe its hw problm,,. Or u can try with usb flash. But ithink same.
Old 01-12-2011, 06:19   #10 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
Thanks Meter: 140
do u have rpl backup
if u have then u can solve it 100%
first full eraze with mxkey then flash any version after that write rpl backup
but if u not have rpl then u cant di it
u just can power on the set but no network couse imei curropt
Old 01-12-2011, 06:43   #11 (permalink)
hand2hand's Avatar
Member: 1476841
Thanks Meter: 201
1st bro, flash usb with usb via mxkey
2nd flash with ub via usb your problem solved
Old 01-14-2011, 03:50   #12 (permalink)
Member: 106488
Thanks Meter: 24
no solved friend
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Old 02-28-2011, 13:47   #13 (permalink)
Member: 1081243
Thanks Meter: 4
5130 water damege restart
mx key flash show the Bootstrap failed!
RX Buffer: 0300
ia m use win 7
mx key v 3.4 rev 1.8
Using device: POTATO BOX, FW ver: 01.B4
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
Processing MCU file: rm495__05.80.mcusw
[BB5,BB5 ALGORITHM] size: 18.12 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 01300105283368502323E85184519625401BA421
ASIC MODE ID: 00
FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,CMT
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 55.473 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 2 min 45.977 s
Processing PPM file: rm495__07.95.ppm_mk
[BB5,BB5 ALGORITHM] size: 7.69 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Bootstrap failed!
RX Buffer: 0300
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? telefonman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-13-2000 20:06
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.28660 seconds with 9 queries
