Old 12-20-2009, 06:53   #1 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
Question 7210c concat servise help Log Here ???
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11446, Date: 25-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1510020A83135950F62380C6C8F3DAF5AA7F74E9
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35196203450736
Original Product code: 0566809
Bluetooth ID: 00247CB19FBD
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 06.51 23-03-09 RM-436 (c) Nokia
Imei plain: 35196203450736-4
Product Code: 0566809
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Please Help Need
Old 12-20-2009, 07:01   #2 (permalink)
Member: 1132214
Thanks Meter: 8
Taray karo new virsn hay rm-436_v7.23 http://depositfiles.com/files/rp7bfpokh
Old 12-20-2009, 07:03   #3 (permalink)
Member: 762728
Sonork: 100.1587901
Thanks Meter: 106
tang inang salita yan
Old 12-20-2009, 07:07   #4 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
Please Help Need
If you have backup write them.
Otherwise RPL is final.
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 12-20-2009, 07:13   #5 (permalink)
Member: 1147614
Thanks Meter: 2
flash+unlock on jaff this can be solved only in software and not in any coil. ok tr
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
Please Help Need
try on jaff using manual flash + unlock on.
Old 12-20-2009, 07:14   #6 (permalink)
Member: 1147614
Thanks Meter: 2
Old 12-20-2009, 07:49   #7 (permalink)
md.nazmul's Avatar
Member: 648428
Thanks Meter: 846
https://forum.gsmhosting.com/vbb/f550/7210c-concat-servise-help-log-here-879838/
Old 12-20-2009, 10:01   #8 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
repair with MT and UB this in available solution
n73 phone startup failer concat the retailer log here Master Software MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-06-2010 20:14
3110c rm 237 contact servise help log here Master Software MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 02-02-2010 07:36
7210c concat servise help Log Here ??? Master Software MXKEY Nokia Flasher and Unlocker (by Alim Hape) 16 12-21-2009 19:02
5130 concat servise help me plz naveedbutt Universalbox 1 12-21-2009 13:13
7210c concat servise help ??? Master Software Universalbox 7 12-21-2009 01:42
Page generated in 0.23240 seconds with 9 queries
