Old 02-10-2010, 08:21   #1 (permalink)
Member: 69514
Thanks Meter: 65
7210c contact service
Is there any way to 7210c contact service with mx key? Here is log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0EC000041E6D7C561585C5CCEC692B9E0BCF47CC
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35196203046700
Original Product code: 0572571
Bluetooth ID: 00247D5A9811
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 05.21 20-10-08 RM-436 (c) Nokia
Imei plain: 35196203046700-1
Product Code: 0566807
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 02-10-2010, 08:39   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
try with standart metods
REPAIR SIMLOCK - Determind first what SL level you got
> Choose Repair SIMLOCK
> Tick make SIMLOCK RPL
> Click Repair SPLock
if have error on repair simlock
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
You got Only NPC? NO PROBLEMO!
br,
ps : if u try searching, u will found same answer like this
Nokia 7210c contact service NIMESHFONOTLY Nokia Hardware & Hardware Repair 78 08-23-2012 14:31
7210c contact service plz hlp fofolpo Nokia Base Band 5 ( BB-5 ) 2 04-02-2009 10:41
Page generated in 0.31662 seconds with 8 queries
